Ubuntu: 18.04
When I tried to do sudo apt-get upgrade it gives me this error:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
libpython3.7-minimal libpython3.7-stdlib
Use 'sudo apt autoremove' to remove them.
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up python3-software-properties (0.96.24.32.7) ...
/var/lib/dpkg/info/python3-software-properties.postinst: 6: /var/lib/dpkg/info/python3-software-properties.postinst: py3compile: not found
dpkg: error processing package python3-software-properties (--configure):
installed python3-software-properties package post-installation script subprocess returned error exit status 127
But suggested commend sudo apt autoremove also shows error:
The following packages will be REMOVED
0 to upgrade, 0 to newly install, 2 to remove and 0 not to upgrade.
After this operation, 12.1 MB disk space will be freed.
(Reading database ... 178285 files and directories currently installed.)
Removing libpython3.7-stdlib:amd64 (3.7.1-1~18.04) ...
Removing libpython3.7-minimal:amd64 (3.7.1-1~18.04) ...
So it looks like there is some problem with py3compile which is not found.
I try sudo apt-get -f install which ends with:
The same kind of py3compile: not found error shows when i try sudo apt-get install --reinstall python3-minimal
I'm new with ubuntu so I will be glad for some help with that.
