I am trying to have multiple USB installers for different OSs, like Debian, Ubuntu, windows, etc. I have an external 2T HDD (Seagate Expansion+) with a single partition in it. What I want to do is to make a few little partitions in it, and burn the different images to those partitions, without affecting the 50 GB of data I have in the main partition, which I can't move anywhere. I just want something like this:
Drive        Size      Bootable
/dev/sdb1 1988 GB
/dev/sdb2 4 GB *
/dev/sdb3 4 GB * /dev/sdb4 4 GB *
With the 4 GB partitions being bootable OS installers, and without formatting the big partition, because there's stuff there I can't move out that I'd like to keep
My operative systems: Grub dual-boot:
  1. ParrotSec OS 4.9 amd64
  2. Windows 7 Home Premium
I have tried:
Multibootusb -> has bugs and doesn't start
dd command -> doesn't support multiboot
Unetbootin -> doesn't support multiboot
YUMI -> it just gives me access to the live part of the ISO, losing the installer, which is part of my plan
Edit: Nevermind, YUMI did the trick, I just accidentally downloaded a live version only of ubuntu instead of the installer
Edit 2: For future reference I'd like to mention that I currently use Ventoy, which allows you to just install the tool on the drive, and then just throw ISO files in it. It will show a GRUB-like menu and allow you to choose why ISO file to boot
MultiBoot using External USB HDD
You can use MultiBootUSB, http://multibootusb.org/, to install multiple OS to a specific partition on an HDD or each OS to it's own partition. Multiple persistence is also possible.
MultiBootUSB 9.2 is working with Ubuntu up to 18.04. It will boot 'buntu 20.04 ISO's placed in the /multibootusb/iso/ folder. Persistence and UEFI boot is working with Linux versions but not with the Windows version of MBUSB.
It is easy to just install GRUB to a hard drive and use that to boot ISO files. The following was written for USB but also works on HDD: How do I create a Multiboot USB that is compatible with both BIOS and UEFI?
C.S.Cameron
  • 20,530
  • 78
  • 125
YUMI works just fine. I can install anything i want in a single partition and choose whatever I want at start-up.
