I am using a Dell XPS l502x laptop dual booted with Windows 10 and Ubuntu 20.04. The internet speed on Windows is fast and stable while it is very slow and unstable while I use Ubuntu, it keeps on dropping. The signal strength is also much weaker when I boot into Ubuntu while it works perfectly in Windows with same conditions.
The output of lspci -nnk | grep -A2 0280:
03:00.0 Network controller [0280]: Intel Corporation Centrino Wireless-N 1030 [Rainbow Peak] [8086:008a] (rev 34)
Subsystem: Intel Corporation Centrino Wireless-N 1030 BGN [8086:5325]
Kernel driver in use: iwlwifi
The output of dmesg | grep iwl:
[ 17.896470] iwlwifi 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 17.974380] iwlwifi 0000:03:00.0: loaded firmware version 18.168.6.1 op_mode iwldvm
[ 18.938665] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUG disabled
[ 18.938672] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
[ 18.938677] iwlwifi 0000:03:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
[ 18.938684] iwlwifi 0000:03:00.0: Detected Intel(R) Centrino(R) Wireless-N 1030 BGN, REV=0xB0
[ 18.975229] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 20.747957] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[ 35.230165] iwlwifi 0000:03:00.0: Radio type=0x2-0x2-0x1
[ 35.326450] iwlwifi 0000:03:00.0: Radio type=0x2-0x2-0x1
The output of sudo lshw -C network:
description: Wireless interface
product: Centrino Wireless-N 1030 [Rainbow Peak]
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: 34
serial: bc:77:37:28:9f:5b
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.4.0-31-generic firmware=18.168.6.1 ip=192.168.0.104 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:39 memory:f1b00000-f1b01fff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:06:00.0
logical name: enp6s0
version: 06
serial: 14:fe:b5:9c:fc:0d
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 firmware=rtl_nic/rtl8168e-2.fw latency=0 link=no multicast=yes port=MII
resources: irq:17 ioport:2000(size=256) memory:f1804000-f1804fff memory:f1800000-f1803fff
I hope this information is enough to help me sort this out, Please let me know if any other information is needed regarding this issue.
