I replaced my HDD with Samsung EVO 860 SSD. I read suggestions that swap partitions should be disabled/removed in order to extend the life of the SSD. However, gparted does not show that I have a swap partition.
Does Ubuntu 20.04 installer automatically skip creating a swap partition when installing on an SSD?
Thanx in advance!
user68186
  • 37,461
Swap is now a file
Ubuntu 20.04 creates a swap file during installation. Swap partitions are not required anymore. This is irrespective of SSD or HDD.
Ubuntu started using a swap file instead of a partition from the version 17.04. See Default 17.04 swap file location for more.
Swap is still needed
The suggestion that you should disable or remove swap from SSD is rather old. it comes from the old time when SSDs would get corrupt with too many writes. Modern SSDs are more robust. So, it is okay to keep a swap file (or a swap partition, if you really need it) in the SSD.
I would keep the default swap file as is in the SSD unless you have some special needs and requirements. If you have enough RAM the swap file may not be used much and won't "speedup" the death of the SSD by any significant time. On the other hand, if you edit videos or work with lots of open tabs in Firefox the swap file will prevent your computer from crashing if it runs out of RAM.
Hope this helps
user68186
  • 37,461
