I have been trying to install nvidia-driver-390 for my graphics card GK107GLM [Quadro K1100M].
Firstly, I tried to follow these instructions. I go through the normal steps of adding the repo and updating my apt-get. But the driver I am looking for is not there.
So I looked into where I can find the correct driver on nvidia.com. I can see nvidia-driver-390 and see my graphics card, Quadro K1100M, listed as supported. I download the .run file and use the instruction provided at How to install NVIDIA.run? and similar one here on Ubuntu Forums to install it. My pre-install fails with the details of /var/log/nvidia-installer.log as given below:
zero@knowzero:/var/log$ more nvidia-installer.log
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sun May 24 11:38:28 2020
installer version: 390.132
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/u sr/local/games
nvidia-installer command line: ./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface -> Detected 8 CPUs online; setting concurrency level to 8. -> Installing NVIDIA driver version 390.132. -> Running distribution scripts executing: '/usr/lib/nvidia/pre-install'... -> done. -> The distribution-provided pre-install script failed! Are you sure you want t o continue? (Answer: Abort installation) ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer. log' for details. You may find suggestions on fixing installation problems in t he README available on the Linux driver download page at www.nvidia.com.
How can I sort this out? I do have the option of continuing with my installation or abort it. I aborted to not do something that would make my computer unusable.
Edit: Just to clarify, the only reason I was using .run file was because when I did
sudo apt-get install nvidia-driver-3
and pressed Tab, I did not get the driver listed. So I thought it is somehow not there in the repository. But when I restarted and tried it again, it worked. I do not know what went wrong initially but it's fine. Seems like I jumped the gun.
Zanna
  • 72,312
Zero
  • 135
The 390 driver is in the official Ubuntu repositories.
It can be installed by
sudo apt install nvidia-driver-390
I can't understand what is the problem. Installing from .run files is wrong for Ubuntu
Pilot6
  • 92,041
