I am running ubuntu 10.10 on a Lenovo ideapad z560. The speakers run fine but the headphones are not recognized when i plug them in. Audio comes out of the speakers only. I tried all alsa and pulseaudio settings but to no avail. I came to know that this is a known bug and many people are having this problem. I was wondering whether shifting to OSS4 would help. I need some advice because once i make the switch i would need to reconfigure a large number of audio apps. Thanks in advance
Jorge Castro
  • 73,717
tinhed
  • 2,468
I would advise that you leave your sound servers alone, maybe you should try if a USB based headphone will help work around the problem until the bug is fixed, also make sure that it is really not a hardware issue, I had an old Dell Inspiron that had a similar problem and it turned out that the problem was hardware failure, Windows that came on it with the proper drivers had the same problem.
Sabacon
  • 41,474
Have you tried to explicitly set the sound card's model in the alsa-base.conf file?
