I would like to learn some useful keyboard shortcuts. I have become a ninja of keyboard shortcuts in Windows.
Any must-have tips for Ubuntu?
Feel free to include Ubuntu defaults or custom ones you have found useful!
You can set up whatever keyboard shortcuts you want through System -> Preferences -> Keyboard Shortcuts. This will also tell you the current shortcuts.
Personally, I activate Ctrl+Alt+Backspace to restart the x server, use Ctrl+Alt+T to open a terminal, Ctrl+Alt+X as the xkill command so I can click on non-responding window to kill it and Ctrl+Alt+Delete to open the system monitor (a la Windows) instead of bringing up the shutdown prompt.
There is also a whole load of keyboard shortcuts set by compiz, which can be
edited using compizconfig-settings-manager1 (installable from repositories).
I find keyboard shortcuts to be a personal preference and we are lucky that Linux is so customisable as to allow whatever configuration we want.
When I found out about Alt + Mouse 1 on an open Window. I went nuts moving windows is easy now.
I also use Ctrl + Alt + (Left|Right) for switching workspaces.
Lastly I find myself using Super + Space which is the default binding for Gnome Do which I love.
Alt + F2 is very handy for starting programs, it has auto-completion and prevents you from clicking though the menus.
In Nautilus, you can have an extra pane by pressing F3. You get a Norton Commander kind of look.
(I learned this here: Add options to "Move to" (when you right click on a file).)
ctrl+alt+l(lock) to lock your desktop.
ALT + F1 : launch applications menu, probably the most used keyword combination in my laptop.
ALT + Home : Jump to home folder.
ALT + Enter : Show file/folder properties.
ALT + F2 : Launch "run application" dialog box.
ALT + F4 : Close Window.
ALT + Left/Right : Go back/forward while navigation directories in nautilus.
ALT + Up/Down : Go up/down while navigating directories in nautilus.
ALT + Tab : Browse through windows.
Shift + Del : Permanently delete files, no backing up in trash folder.
F2 : Rename File/Folder.
F3 : Enable split view in nautilus.
F8 : Show/hide nautilus menubar.
F9 : Toggle nautilus side-pane.
Super + Tab : "Shift switcher", need to enable it in CCSM.
Super + M : Inverts all the colors.
Super + A or W : Arrange windows in a nice panel like appearance(Need Compiz).
CTRL + L : View/Edit full location path.
CTRL + A : Select all.
CTRL + N : New window.
CTRL + Shift + N : New folder.
CTRL + H : Show/hide hidden files.
CTRL + ALT + L : Lock Screen.
From http://www.techdrivein.com/2010/08/20-useful-ubuntugnome-keyboard.html
If your system has become complete unresponsive to where even hitting CTRL+ALT+F1 doesn't give you a terminal, it is possible to still gracefully stop your machine and reboot.
ALT+SysReq+r : Raw keyboard mode
ALT+SysReq+s : Sync the disk
ALT+SysReq+e : Terminate all processes
ALT+SysReq+i : Kill remaining process
ALT+SysReq+u : Remount all filesystems as read only
ALT+SysReq+b : Reboot
(Another way to kill all processes: ALT+SysReq+k)
Ctrl+W: Close Window/Tab
Ctrl+Q: Quit Application
Alt+F2: Open Run Application
SuperKey+Space: Runs Gnome-Do if installed (Very Cool App)
Once you get Compiz Fusion installed there are a ton of nifty keyboard shortcuts. It's like Exposé on Mac OS X, but even more powerful. I have shortcuts set up to flip between desktops, zoom out/show all windows, show the desktop, launch the console, etc. If you've never used Compiz check it out:
Haven't seen any shell related shortcuts yet, so here's a few I use a lot in bash:
Ctrl+R: Search incrementally backwards through command history.
Ctrl+T: Exchange characters under and behind the cursor.
Alt+.: Insert last argument from previous command.
Another few helpful shortcuts while in terminal:
Ctrl+Shift+C: Copy.
Ctrl+Shift+V: Paste.
Ctrl+Arrow Left: Move to the start of the previous string (for long commands).
Ctrl+Arrow Right: Move to the next non-alphabet character (eg, '/', '.', '_', '-', etc).
Arrow Up or Arrow Down: Scroll through history of commands.
ctrl-alt-d is useful for quickly minimizing/restoring all the applications on the desktop.
Some shortcuts relating to the mouse:
Alt + F7 Move windows without using the mouse.
Alt + F8 Resize window without using the mouse.
Alt + F9 Minimizes the focused window.
Alt + F10 Toggles maximize.
Alt + Tab Cycle through open windows (bouth windows minimized and not-minimized)
I like using Ctrl + arrow keys to switch workspaces. I do it a lot. It's fun. I use Ctrl + Alt + arrow keys to move windows.
Super-T to open the terminal.
I took a note from the guy above, and made an xkill shortcut--I use Ctrl + Alt + X.
Alt + Tab is handy as always, but less so, as I just put things on different desktops.
As noted above, using compiz config is wise.
Anyway, there's a reason you're able to customize them all. Get a feel for what you need to do, and how you want to do it. Come on, man, you're using Ubuntu. Go nuts.
These might not be a shortcuts but they do involve using the keyboard: turn on Mouse Keys in Keyboard Preferences and by pressing Fn + [keys that have the same colour as the "Fn" label] you can control the pointer and simulate clicks and click-holds. Keynav is a program in the repositories that is used to control the pointer by using the keyboard to divide a window in half continually. Thus one can click a link with no more than 10 key presses (in the rare case that Vimium/Pentadactyl/Vimperator can't do the job). Long winded it is, but I haven't touched a mouse or trackpad in ages!
Only vaguely on-topic, but I like rebinding the Caps Lock key to the Compose Key. Preferences > Keyboard > Layouts > Options > Compose Key Position, set to caps lock. Try it! Done? Now press Caps Lock, then apostrophe, then e. Voila, e with an accent.
Alt+F1 to pop up a main menu at your mouse pointers position.
Alt+F2 to execute commands.
If you haven't looked through the emacs tutorial yet, you might want to. It's got a bunch of keyboard shortcuts that apply to the bash prompt and throughout linux in general.
$ emacs
C-h t
Good luck!
Well, you can get go on System then Preferences and then Keyboard Shortcuts. You will see the ones that are in use and you can also edit to any key/keys you like or can remember easily...
