I just installed ubuntu 12.04 and wanted to use the gnome 3 shell, according to this site it was just a matter of installing the gnome shell as gnome 3 is already part of ubuntu 12.04
So I did sudo apt-get install gnome-shell and logged out, selected gnome and logged in and I was looking at gnome 2 instead of 3. What went wrong?
Timotheus
  • 143
gnome-shell requires some level of 3D hardware-acceleration to work.
It doesn't have to be special hardware - integrated graphics should in almost all cases be fine. But 3D acceleration must be working.
Gnome 3's window manager, mutter, is a compositing window manager that is OpenGL accelerated.
If gnome-shell doesn't detect that you have the right capabilities, it'll load into a "fallback mode" which means it loads an old-style panel that looks like Gnome 2 and it doesn't use a compositing window manager.
Ubuntu has helpful ways of installing proprietary drivers for graphics - have you tried these?
thomasrutter
  • 37,804
What the OP is seeing is the "old gnome 3". Gnome 3.4 is using llvmpipe to support older hardware.
Here is what gnome-shell now looks like in fallback mode (screenshot is taken with an intel GMA500 using the psb_gfx driver, which is 2d only).
gnome-shell
As of my post today, the latest versions of gnome-shell and llvmpipe have not yet been fully ported to Ubuntu or a ppa.
There is a ppa for llvmpipe, but because llvmpipe is under rapid development it is currently better to build it from source (git).
See How to install LLVMpipe?
Panther
  • 104,528
I had the same problem. If you're using an ATI Radeon graphics card like me, this might be the solution:
http://onubuntu.blogspot.ca/2011/10/manually-removing-fglrx-from-ubuntu.html
Here's a copy/paste of the important bits:
~$ sudo apt-get purge xorg-driver-fglrx
~$ sudo apt-get install --reinstall libgl1-mesa-glx libgl1-mesa-dri
~$ sudo dpkg-reconfigure xserver-xorg
~$ sudo apt-get install --reinstall xserver-xorg-core
This thread just saved me thanks! Full story:
Fresh install of Linux Mint 13 (Maya) on a Lenovo Thinkpad T520 with this driver : 01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [Quadro NVS 4200M] (rev a1)
I got gnome-shell with 3D working.
$ sudo apt-get install gnome-shell gnome-session gnome-tweak-tool
I switch to nvidia (I am a sucker for pain) : [http://forums.linuxmint.com/viewtopic.php?f=59&t=154932][1]
This works great for my external monitor but totally hoses my laptop display. For maybe the wrong reasons I decide to revert to revert to nouveau
$ sudo apt-get purge nvidia*
$ sudo apt-get install xserver-xorg-video-nouveau xserver-xorg-video-all
$ sudo rm /etc/modprobe.d/nvidia-installer-disable-nouveau.conf
This leaves me without openGL so gnome goes into 2D fallback mode. I verify this by running the gnome-shell --replace:
$ gnome-shell --replace
Xlib:  extension "GLX" missing on display ":0.0".
Following the steps to reinstall / reconfigure glx from above:
$ sudo reboot
And I was back in business!
zayquan
  • 101
