I am not able to meet all the dependencies needed to install Wine.
I have followed all the instructions as on the Ubuntu page on the WineHQ wiki.
But when I do sudo apt install winehq-stable, my computer shows:
Reading package lists... Done
Building dependency tree
The following information may help to resolve the situation
winehq-stable : Depends: wine-stable (= 4.0.4~focal)
Then when I do sudo apt install wine-stable:
wine-stable : Depends: wine-stable-amd64 (= 4.0.4~focal) but 5.0.0~eoan is to be installed
Depends: wine-stable-i386 (= 4.0.4~focal)
Then when i do sudo apt install wine-stable-amd64 wine-stable-i386:
wine-stable-amd64 is already the newest version (5.0.0~eoan).
wine-stable-i386:i386 : Depends: libasound2:i386 (>= 1.0.16) but it is not going to be installed
Depends: libc6:i386 (>= 2.29) but it is not going to be installed
Depends: libglib2.0-0:i386 (>= 2.12.0) but it is not going to be installed
Depends: libgphoto2-6:i386 (>= 2.5.10) but it is not going to be installed
Depends: libgphoto2-port12:i386 (>= 2.5.10) but it is not going to be installed
Depends: libgstreamer-plugins-base1.0-0:i386 (>= 1.0.0) but it is not going to be installed
Depends: libgstreamer1.0-0:i386 (>= 1.4.0) but it is not going to be installed
Depends: liblcms2-2:i386 (>= 2.2+git20110628) but it is not going to be installed
Depends: libldap-2.4-2:i386 (>= 2.4.7) but it is not going to be installed
Depends: libmpg123-0:i386 (>= 1.13.7) but it is not going to be installed
Depends: libopenal1:i386 (>= 1.14) but it is not going to be installed
Depends: libpcap0.8:i386 (>= 0.9.8) but it is not going to be installed
Depends: libpulse0:i386 (>= 0.99.1) but it is not going to be installed
Depends: libudev1:i386 (>= 183) but it is not going to be installed
Depends: libvkd3d1:i386 (>= 1.0) but it is not going to be installed
Depends: libx11-6:i386 but it is not going to be installed
Depends: libxext6:i386 but it is not going to be installed
Depends: libxml2:i386 (>= 2.9.0) but it is not going to be installed
Depends: ocl-icd-libopencl1:i386 but it is not going to be installed or
libopencl1:i386
Depends: ocl-icd-libopencl1:i386 (>= 1.0) but it is not going to be installed or
libopencl-1.1-1:i386
Depends: zlib1g:i386 (>= 1:1.1.4) but it is not going to be installed
Depends: libasound2-plugins:i386 but it is not going to be installed
Depends: libncurses6:i386 but it is not going to be installed or
libncurses5:i386 but it is not going to be installed or
libncurses:i386 but it is not installable
Recommends: libcapi20-3:i386 but it is not going to be installed
Recommends: libcups2:i386 but it is not going to be installed
Recommends: libdbus-1-3:i386 but it is not going to be installed
Recommends: libfontconfig1:i386 but it is not going to be installed
Recommends: libfreetype6:i386 but it is not going to be installed
Recommends: libglu1-mesa:i386 but it is not going to be installed or
libglu1:i386
Recommends: libgnutls30:i386 but it is not going to be installed or
libgnutls28:i386 but it is not installable or
libgnutls26:i386 but it is not installable
Recommends: libgsm1:i386 but it is not going to be installed
Recommends: libgssapi-krb5-2:i386 but it is not going to be installed
Recommends: libjpeg62-turbo:i386 but it is not installable or
libjpeg8:i386 but it is not going to be installed
Recommends: libkrb5-3:i386 but it is not going to be installed
Recommends: libodbc1:i386 but it is not going to be installed
Recommends: libosmesa6:i386 but it is not going to be installed
Recommends: libpng16-16:i386 but it is not going to be installed or
libpng12-0:i386 but it is not installable
Recommends: libsane:i386 but it is not going to be installed or
libsane1:i386
Recommends: libsdl2-2.0-0:i386 but it is not going to be installed
Recommends: libtiff5:i386 but it is not going to be installed
Recommends: libv4l-0:i386 but it is not going to be installed
Recommends: libxcomposite1:i386 but it is not going to be installed
Recommends: libxcursor1:i386 but it is not going to be installed
Recommends: libxfixes3:i386 but it is not going to be installed
Recommends: libxi6:i386 but it is not going to be installed
Recommends: libxinerama1:i386 but it is not going to be installed
Recommends: libxrandr2:i386 but it is not going to be installed
Recommends: libxrender1:i386 but it is not going to be installed
Recommends: libxslt1.1:i386 but it is not going to be installed
Recommends: libxxf86vm1:i386 but it is not going to be installed
