I have tried to follow the official guide but unfortunately, there is something wrong with dependencies.
$ sudo apt install winehq-stable
The following packages have unmet dependencies.
 winehq-stable : Depends: wine-stable (= 5.0.0~eoan)
$ sudo apt install wine-stable
 wine-stable : Depends: wine-stable-i386 (= 5.0.0~eoan)
$ sudo apt install wine-stable-i386
 wine-stable-i386:i386 : Depends: libfaudio0:i386 (>= 19.06.07) but it is not going to be installed
                         Depends: libglib2.0-0:i386 (>= 2.12.0) but it is not going to be installed
                         Depends: libgstreamer-plugins-base1.0-0:i386 (>= 1.0.0) but it is not going to be installed
                         Depends: libgstreamer1.0-0:i386 (>= 1.4.0) but it is not going to be installed
                         Recommends: libcups2:i386 but it is not going to be installed
                         Recommends: libgssapi-krb5-2:i386 but it is not going to be installed
                         Recommends: libkrb5-3:i386 but it is not going to be installed
                         Recommends: libodbc1:i386 but it is not going to be installed
                         Recommends: libsane:i386 but it is not going to be installed or
                                     libsane1:i386
... many steps in between, and the last one is quite dangerous to me.
$ sudo apt install libpcre2-8-0:i386
The following NEW packages will be installed
  libpcre2-8-0:i386 pinentry-curses
WARNING: The following essential packages will be removed.
This should NOT be done unless you know exactly what you are doing!
  apt adduser (due to apt) coreutils libselinux1 (due to coreutils) dash dpkg (due to dash) debconf (due to dash) tar (due to dpkg) fdisk libmount1 (due to fdisk) findutils grep
  install-info (due to grep) gzip init systemd-sysv (due to init) init-system-helpers (due to init) perl-base (due to init-system-helpers) login libpam0g (due to login)
  libpam-runtime (due to login) libpam-modules (due to login) mount util-linux (due to mount) sed sysvinit-utils
0 to upgrade, 2 to newly install, 1594 to remove and 0 not to upgrade.
Need to get 218 kB of archives.
After this operation, 9.097 MB disk space will be freed.
You are about to do something potentially harmful
To continue type in the phrase ‘Yes, do as I say!’
How to resolve this dependency hell?
UPDATE
Some info on configured repos (also viewable here):
$ grep -r ^deb /etc/apt/ --include="*.list"
/etc/apt/sources.list.d/vscode.list:deb [arch=amd64] http://packages.microsoft.com/repos/vscode stable main
/etc/apt/sources.list.d/nordvpn.list:deb https://repo.nordvpn.com/deb/nordvpn/debian stable main
/etc/apt/sources.list.d/team-xbmc-ubuntu-ppa-eoan.list:deb http://ppa.launchpad.net/team-xbmc/ppa/ubuntu eoan main
/etc/apt/sources.list.d/thopiekar-ubuntu-cura-eoan.list:deb http://ppa.launchpad.net/thopiekar/cura/ubuntu eoan main
/etc/apt/sources.list.d/spotify.list:deb http://repository.spotify.com stable non-free
/etc/apt/sources.list.d/papirus-ubuntu-papirus-eoan.list:deb http://ppa.launchpad.net/papirus/papirus/ubuntu eoan main
/etc/apt/sources.list.d/slack.list:deb https://packagecloud.io/slacktechnologies/slack/debian/ jessie main
/etc/apt/sources.list.d/google-chrome.list:deb [arch=amd64] http://dl.google.com/linux/chrome/deb/ stable main
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ eoan main restricted
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ eoan-updates main restricted
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ eoan universe
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ eoan-updates universe
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ eoan multiverse
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ eoan-updates multiverse
/etc/apt/sources.list:deb http://de.archive.ubuntu.com/ubuntu/ eoan-backports main restricted universe multiverse
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu eoan-security main restricted
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu eoan-security universe
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu eoan-security multiverse
/etc/apt/sources.list:deb https://dl.winehq.org/wine-builds/ubuntu/ eoan main
$ dpkg --print-foreign-architectures
i386
$ apt-cache policy winehq-stable wine-stable
winehq-stable:
  Installed: (none)
  Candidate: 5.0.0~eoan
  Version table:
     5.0.0~eoan 500
        500 https://dl.winehq.org/wine-builds/ubuntu eoan/main amd64 Packages
     4.0.3~eoan 500
wine-stable:
  Installed: (none)
  Version table:
     5.0.0~eoan 500
     4.0.3~eoan 500
     3.0.1ubuntu1 500
        500 http://de.archive.ubuntu.com/ubuntu eoan/universe amd64 Packages
        500 http://de.archive.ubuntu.com/ubuntu eoan/universe i386 Packages
(Also viewable here.)
$ dpkg -l | grep -i wine
ii | libkwineffects12 | 4:5.16.5-0ubuntu1 | amd64 | KDE window manager effects library
ii | wine-stable-amd64 | 5.0.0~eoan | amd64 | WINE Is Not An Emulator - runs MS Windows programs
UPDATE #2:
I have upgraded to 20.40 and to install in two different ways:
$ sudo apt install --install-recommends winehq-stable           4704  21:14:36    kubesail-alexey-anufriev/alexey-anufriev ⎈
Reading package lists... Done
Building dependency tree
 winehq-stable : Depends: wine-stable (= 4.0.4~focal)
And:
sudo apt install wine64 wine32         100 ↵  4705  21:15:40    kubesail-alexey-anufriev/alexey-anufriev ⎈
 wine32:i386 : Depends: libwine:i386 (= 5.0-3ubuntu1) but it is not going to be installed
Still no luck.
UPDATE 3
$ sudo aptitude install winehq-stable
The following NEW packages will be installed:
  gstreamer1.0-plugins-base:i386{a} libglib2.0-0:i386{a} libgstreamer-plugins-base1.0-0:i386{a} libgstreamer1.0-0:i386{a} libodbc1:i386{ab} libpcre3:i386{ab}
  wine-stable{a} wine-stable-amd64{a} wine-stable-i386:i386{a} winehq-stable{b}
0 packages upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
Need to get 52,3 MB of archives. After unpacking 466 MB will be used.
 libodbc1 : Breaks: libodbc1:i386 (!= 2.3.7) but 2.3.6-0.1build1 is to be installed
 libodbc1:i386 : Breaks: libodbc1 (!= 2.3.6-0.1build1) but 2.3.7 is installed
 libpcre3 : Breaks: libpcre3:i386 (!= 2:8.43-1+ubuntu18.04.1+deb.sury.org+1) but 2:8.39-12build1 is to be installed
 libpcre3:i386 : Breaks: libpcre3 (!= 2:8.39-12build1) but 2:8.43-1+ubuntu18.04.1+deb.sury.org+1 is installed
 winehq-stable : Conflicts: wine but 5.0-3ubuntu1 is installed
                 Conflicts: wine:i386 which is a virtual package, provided by:
                            - winehq-staging:i386 (5.9~focal), but it is not going to be installed
                            - winehq-staging:i386 (5.8~focal), but it is not going to be installed
                            - winehq-staging:i386 (5.7~focal), but it is not going to be installed
                            - winehq-stable:i386 (4.0.4~focal), but it is not going to be installed
                            - winehq-devel:i386 (5.9~focal), but it is not going to be installed
                            - winehq-devel:i386 (5.8~focal), but it is not going to be installed
                            - winehq-devel:i386 (5.7~focal), but it is not going to be installed
                            - wine (5.0-3ubuntu1), but 5.0-3ubuntu1 is installed
                            - wine-development (5.5-3ubuntu1), but it is not going to be installed
The following actions will resolve these dependencies:
      Keep the following packages at their current version:
1)      gstreamer1.0-plugins-base:i386 [Not Installed]
2)      libglib2.0-0:i386 [Not Installed]
3)      libgstreamer-plugins-base1.0-0:i386 [Not Installed]
4)      libgstreamer1.0-0:i386 [Not Installed]
5)      libodbc1:i386 [Not Installed]
6)      libpcre3:i386 [Not Installed]
7)      wine-stable [Not Installed]
8)      wine-stable-i386:i386 [Not Installed]
9)      winehq-stable [Not Installed]
      Leave the following dependencies unresolved:
10)     libgstreamer-plugins-base1.0-0:i386 recommends gstreamer1.0-plugins-base:i386
11)     wine-stable-i386:i386 recommends libodbc1:i386
Accept this solution? [Y/n/q/?] Y
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
$ apt-cache policy winehq-stable wine-stable wine32 wine64
winehq-stable:
  Installed: (none)
  Candidate: 4.0.4~focal
  Version table:
     4.0.4~focal 500
        500 https://dl.winehq.org/wine-builds/ubuntu focal/main amd64 Packages
wine-stable:
  Installed: (none)
  Version table:
     4.0.4~focal 500
     3.0.1ubuntu1 500
        500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
        500 http://de.archive.ubuntu.com/ubuntu focal/universe i386 Packages
wine32:i386:
  Installed: (none)
  Candidate: 5.0-3ubuntu1
  Version table:
     5.0-3ubuntu1 500
wine64:
  Installed: 5.0-3ubuntu1
  Version table:
 *** 5.0-3ubuntu1 500
        100 /var/lib/dpkg/status
Eliah Kagan
  • 119,640
As you are using modern Ubuntu 20.04 LTS - I would recommend to remove WineHQ repository and install Wine 5.0.3 from universe:
sudo add-apt-repository -r 'deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main'
sudo add-apt-repository -r 'deb https://dl.winehq.org/wine-builds/ubuntu/ cosmic main'
sudo add-apt-repository -r 'deb https://dl.winehq.org/wine-builds/ubuntu/ disco main'
sudo add-apt-repository -r 'deb https://dl.winehq.org/wine-builds/ubuntu/ eoan main'
sudo add-apt-repository -r 'deb https://dl.winehq.org/wine-builds/ubuntu/ focal main'
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get dist-upgrade # to get newest dependencies
Below I summarize steps done in the comments:
# remove obsolete PPA
sudo add-apt-repository -r ppa:gnome3-team/gnome3
# check real reason of the problem
sudo apt-get install aptitude
sudo aptitude install wine32:i386
By last command we have determined that there are several locally (previously from some repository) installed packages. We need to replace them with versions from the official repositories:
sudo aptitude install libfaudio0=20.04-2 libodbc1=2.3.6-0.1build1 libpcre3=2:8.39-12build1
And finally install Wine:
sudo apt-get install wine wine32
N0rbert
  • 103,263
