47
Just updated to 20.04 final release, and I'm seeing these messages in /var/log/auth.log...
May 14 06:29:52 Satellite-E55 gdm-password]: pam_unix(gdm-password:auth): Couldn't open /etc/securetty: No such file or directory
May 14 07:40:14 Satellite-E55 su: pam_unix(su:auth): Couldn't open /etc/securetty: No such file or directory
I looked back at a 19.10 VM, and /etc/securetty was there. All my 20.04 systems are missing this file. Two 20.04 installations are upgrades, and one installation is a fresh install VM.
What's up with this file missing in 20.04? Should I restore a copy from 19.10?
Update #1:
The same problem occurs in 20.10, in both upgrades and fresh installs.
heynnema
  • 73,649
There is an example file that you can copy.
sudo cp /usr/share/doc/util-linux/examples/securetty /etc/securetty
17
Here's a copy of /etc/securetty from a 19.10 desktop installation. Only tested for a couple of minutes, but so far /var/log/auth.log is quiet.
When placed into /etc the file should look like this:
-rw-r--r-- 1 root root 4.1K May 14 10:31 securetty
Here are the /etc/securetty contents:
# /etc/securetty: list of terminals on which root is allowed to login.
# See securetty(5) and login(1).
console
Local X displays (allows empty passwords with pam_unix's nullok_secure)
:0 :0.0 :0.1 :1 :1.0 :1.1 :2 :2.0 :2.1 :3 :3.0 :3.1 #...
TTYs sorted by major number according to Documentation/devices.txt
Virtual consoles
tty1 tty2 tty3 tty4 tty5 tty6 tty7 tty8 tty9 tty10 tty11 tty12 tty13 tty14 tty15 tty16 tty17 tty18 tty19 tty20 tty21 tty22 tty23 tty24 tty25 tty26 tty27 tty28 tty29 tty30 tty31 tty32 tty33 tty34 tty35 tty36 tty37 tty38 tty39 tty40 tty41 tty42 tty43 tty44 tty45 tty46 tty47 tty48 tty49 tty50 tty51 tty52 tty53 tty54 tty55 tty56 tty57 tty58 tty59 tty60 tty61 tty62 tty63
UART serial ports
ttyS0 ttyS1 ttyS2 ttyS3 ttyS4 ttyS5 #...ttyS191
Serial Mux devices (Linux/PA-RISC only)
ttyB0 ttyB1 #...
Chase serial card
ttyH0 ttyH1 #...
Cyclades serial cards
ttyC0 ttyC1 #...ttyC31
Digiboard serial cards
ttyD0 ttyD1 #...
Stallion serial cards
ttyE0 ttyE1 #...ttyE255
Specialix serial cards
ttyX0 ttyX1 #...
Comtrol Rocketport serial cards
ttyR0 ttyR1 #...
SDL RISCom serial cards
ttyL0 ttyL1 #...
Hayes ESP serial card
ttyP0 ttyP1 #...
Computone IntelliPort II serial card
ttyF0 ttyF1 #...ttyF255
Specialix IO8+ serial card
ttyW0 ttyW1 #...
Comtrol VS-1000 serial controller
ttyV0 ttyV1 #...
ISI serial card
ttyM0 ttyM1 #...
Technology Concepts serial card
ttyT0 ttyT1 #...
Specialix RIO serial card
ttySR0 ttySR1 #...ttySR511
Chase Research AT/PCI-Fast serial card
ttyCH0 ttyCH1 #...ttyCH63
Moxa Intellio serial card
ttyMX0 ttyMX1 #...ttyMX127
SmartIO serial card
ttySI0 ttySI1 #...
USB dongles
ttyUSB0 ttyUSB1 ttyUSB2 #...
LinkUp Systems L72xx UARTs
ttyLU0 ttyLU1 ttyLU2 ttyLU3
StrongARM builtin serial ports
ttySA0 ttySA1 ttySA2
SCI serial port (SuperH) ports and SC26xx serial ports
ttySC0 ttySC1 ttySC2 ttySC3 ttySC4 ttySC5 ttySC6 ttySC7 ttySC8 ttySC9
ARM "AMBA" serial ports
ttyAM0 ttyAM1 ttyAM2 ttyAM3 ttyAM4 ttyAM5 ttyAM6 ttyAM7 ttyAM8 ttyAM9 ttyAM10 ttyAM11 ttyAM12 ttyAM13 ttyAM14 ttyAM15
Embedded ARM AMBA PL011 ports (e.g. emulated by QEMU)
ttyAMA0 ttyAMA1 ttyAMA2 ttyAMA3
DataBooster serial ports
ttyDB0 ttyDB1 ttyDB2 ttyDB3 ttyDB4 ttyDB5 ttyDB6 ttyDB7
SGI Altix console ports
ttySG0
Motorola i.MX ports
ttySMX0 ttySMX1 ttySMX2
Marvell MPSC ports
ttyMM0 ttyMM1
PPC CPM (SCC or SMC) ports
ttyCPM0 ttyCPM1 ttyCPM2 ttyCPM3 ttyCPM4 ttyCPM5
Altix serial cards
ttyIOC0 ttyIOC1 #...ttyIOC31
NEC VR4100 series SIU
ttyVR0
NEC VR4100 series SSIU
ttyVR1
Altix ioc4 serial cards
ttyIOC84 ttyIOC85 #...ttyIOC115
Altix ioc3 serial cards
ttySIOC0 ttySIOC1 #...ttySIOC31
PPC PSC ports
ttyPSC0 ttyPSC1 ttyPSC2 ttyPSC3 ttyPSC4 ttyPSC5
ATMEL serial ports
ttyAT0 ttyAT1 #...ttyAT15
Hilscher netX serial port
ttyNX0 ttyNX1 #...ttyNX15
Xilinx uartlite - port
ttyUL0 ttyUL1 ttyUL2 ttyUL3
Xen virtual console - port 0
xvc0
pmac_zilog - port
ttyPZ0 ttyPZ1 ttyPZ2 ttyPZ3
TX39/49 serial port
ttyTX0 ttyTX1 ttyTX2 ttyTX3 ttyTX4 ttyTX5 ttyTX6 ttyTX7
SC26xx serial ports (see SCI serial ports (SuperH))
MAX3100 serial ports
ttyMAX0 ttyMAX1 ttyMAX2 ttyMAX3
OMAP serial ports
ttyO0 ttyO1 ttyO2 ttyO3
User space serial ports
ttyU0 ttyU1
A2232 serial card
ttyY0 ttyY1
IBM 3270 terminal Unix tty access
3270/tty1 3270/tty2 #...
IBM iSeries/pSeries virtual console
hvc0 hvc1 #... #IBM pSeries console ports hvsi0 hvsi1 hvsi2
Equinox SST multi-port serial boards
ttyEQ0 ttyEQ1 #...ttyEQ1027
Not in Documentation/Devices.txt
Embedded Freescale i.MX ports
ttymxc0 ttymxc1 ttymxc2 ttymxc3 ttymxc4 ttymxc5
LXC (Linux Containers)
lxc/console lxc/tty1 lxc/tty2 lxc/tty3 lxc/tty4
Serial Console for MIPS Swarm
duart0 duart1
s390 and s390x ports in LPAR mode
ttysclp0
ODROID XU4 serial console
ttySAC0 ttySAC1 ttySAC2 ttySAC3
heynnema
  • 73,649
This is not answer. Only an initial attempt to find the correct solution.
The action mentioned at https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=931899#17 which is to remove secure_nullok [sic] (probably meaning nullok_secure) from the line:
auth    [success=1 default=ignore]  pam_unix.so nullok_secure
at file /etc/pam.d/common-auth seems to work or at least the message is no longer displayed in /var/log/auth.log after this change.
However, looking at a new Ubuntu 20.04 installation I see that this file is similar (with nullok_secure present) and this system too has the same problem of displaying Couldn't open /etc/securetty message. I tested with the login command.
I conclude that this is not an upgrade problem. The problem is present in new installations also.
Please comment...
FedKad
  • 13,420
