This is my PC at work. It is Dell Precision 3630 Tower Workstation. When we purchased it, it initially came with one 256 gb ssd + 1 tb hd. I had Kubuntu 18.04 installed on it with root on the ssd and /home on the HD.
The issue I am having is basically any application I have open, there is like 20% chance for it to crash every 20 min. I use mostly Visual Studio Code (VS code) on it and literally every 20-40 min, the editor stops responding and I have to wait until it says to reopen or exit (I don't lose any files/unsaved data in this program). I believe VS code spawns multiple processes and only one process crashes since I can still click on the menubar. Also, different windows don't crash. It is just anything inside the crashed window is not responding.
This issue is not exclusive to VS code, Google Chrome and other work applications crash and disappear completely. In addition, a notification shows up every once in a while saying Ethernet connection disconnected then reconnected 1 sec after. No internet is lost.
I thought the issue might be with KDE plasma 5 (since this was the first time I use it), so I installed Gnome and the issue was the same. Also note that I have 32GB RAM on this PC (with 4GB swap) so running out of memory is never an issue.
I did the following and all of them failed (mostly hardware):
- I installed a newer kernel (5.7) and still same issue.
- I removed the ssd and hd and installed a new 1tb ssd and installed Kubuntu 20.04 from scratch on it (root and /home in same partition). Same issue.
- I did a memory test using memtest86 (https://www.memtest86.com/). No issues in 2 hour run (Also tested again in diagnostic tools)
- There is a Built-in self test (BIST) with the PSU. I tested it. No issues.
- I ran the diagnostic tools that comes in the BIOS. It tests CPU/GPU/memory/network card/HD/PCIe bus/cables/fans with different stress tests. No issues.
The PC is reported to support Linux (We bought it with Ubuntu 18.04 preinstalled). I also have latest BIOS firmware for this PC (reset it too) and latest firmware for the new SSD (1TB Samsung 860 EVO).
I am not sure what is causing this issue and I tried almost everything with no hint on the cause. Any suggestion on how to fix this issue. Below is link to logs from /var/log/syslog for 1 hour where VS code crashed once and the LAN connection restarted twice (changed name/ip for privacy reason)
Specs:
- CPU: Intel Core i7-8700 @ 3.20GHz, 6 Cores, 12 Logical
- RAM: 2x16 GB (2666MHz)
- GPU: AMD Radeon Pro WX 2100
Edit: VS Code crashed 5 minutes ago. Here is the output of journalctl in the past 5 min.
-- Logs begin at Fri 2020-07-17 20:41:33 EDT, end at Sun 2020-07-26 17:23:31 EDT. --
Jul 26 17:18:55 PC1-Linux1 systemd[1]: Starting Message of the Day...
Jul 26 17:18:55 PC1-Linux1 systemd[1]: motd-news.service: Succeeded.
Jul 26 17:18:55 PC1-Linux1 systemd[1]: Finished Message of the Day.
Jul 26 17:22:38 PC1-Linux1 kernel: traps: code[1671] general protection fault ip:55dacd92bda9 sp:7ffdef785fe0 error:0 in code[55dacc0bb000+51c7000]
Jul 26 17:23:28 PC1-Linux1 sudo[3151]: pam_unix(sudo:auth): Couldn't open /etc/securetty: No such file or directory
Jul 26 17:23:31 PC1-Linux1 sudo[3151]: pam_unix(sudo:auth): Couldn't open /etc/securetty: No such file or directory
Jul 26 17:23:31 PC1-Linux1 sudo[3151]: user1 : TTY=pts/2 ; PWD=/home/user1 ; USER=root ; COMMAND=/usr/bin/journalctl --since=-5 minutes
Jul 26 17:23:31 PC1-Linux1 sudo[3151]: pam_unix(sudo:session): session opened for user root by (uid=0)
Edit2: LAN connection crashed too. Adding output of journalctl in the past 5 min
Jul 26 17:36:49 PC1-Linux1 sudo[3469]: pam_unix(sudo:session): session closed for user root
Jul 26 17:40:12 PC1-Linux1 NetworkManager[704]: <error> [1595799612.7782] dhcp4 (eno1): error -113 dispatching events
Jul 26 17:40:12 PC1-Linux1 NetworkManager[704]: <info> [1595799612.7782] dhcp4 (eno1): state changed bound -> fail
Jul 26 17:40:12 PC1-Linux1 NetworkManager[704]: <info> [1595799612.7783] device (eno1): DHCPv4: trying to acquire a new lease within 90 seconds
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6503] device (eno1): DHCPv4: grace period expired
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6504] device (eno1): state change: activated -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <warn> [1595799702.6548] device (eno1): Activation: failed for connection 'Wired connection 1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6559] manager: NetworkManager state is now CONNECTED_LOCAL
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6562] device (eno1): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Jul 26 17:41:42 PC1-Linux1 avahi-daemon[698]: Withdrawing address record for MAC_REMOVED on eno1.
Jul 26 17:41:42 PC1-Linux1 avahi-daemon[698]: Leaving mDNS multicast group on interface eno1.IPv6 with address MAC_REMOVED.
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6568] dhcp4 (eno1): canceled DHCP transaction
Jul 26 17:41:42 PC1-Linux1 avahi-daemon[698]: Interface eno1.IPv6 no longer relevant for mDNS.
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6568] dhcp4 (eno1): state changed fail -> done
Jul 26 17:41:42 PC1-Linux1 avahi-daemon[698]: Withdrawing address record for REMOVED_IP51 on eno1.
Jul 26 17:41:42 PC1-Linux1 avahi-daemon[698]: Leaving mDNS multicast group on interface eno1.IPv4 with address REMOVED_IP51.
Jul 26 17:41:42 PC1-Linux1 avahi-daemon[698]: Interface eno1.IPv4 no longer relevant for mDNS.
Jul 26 17:41:42 PC1-Linux1 dbus-daemon[702]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.10' (uid=0 pid=704 comm="/usr/sbin/NetworkManager --no-daemon " label="unc>
Jul 26 17:41:42 PC1-Linux1 systemd[1]: Starting Network Manager Script Dispatcher Service...
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6629] policy: auto-activating connection 'Wired connection 1' (80d4d697-a540-3f51-9017-549c2ae2ce5b)
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6639] device (eno1): Activation: starting connection 'Wired connection 1' (80d4d697-a540-3f51-9017-549c2ae2ce5b)
Jul 26 17:41:42 PC1-Linux1 avahi-daemon[698]: Joining mDNS multicast group on interface eno1.IPv6 with address MAC_REMOVED.
Jul 26 17:41:42 PC1-Linux1 whoopsie[1011]: [17:41:42] Cannot reach: https://daisy.ubuntu.com
Jul 26 17:41:42 PC1-Linux1 whoopsie[1011]: [17:41:42] offline
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6640] device (eno1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 26 17:41:42 PC1-Linux1 avahi-daemon[698]: New relevant interface eno1.IPv6 for mDNS.
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6642] manager: NetworkManager state is now CONNECTING
Jul 26 17:41:42 PC1-Linux1 avahi-daemon[698]: Registering new address record for MAC_REMOVED on eno1.*.
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6644] device (eno1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 26 17:41:42 PC1-Linux1 dbus-daemon[702]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6649] device (eno1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6651] dhcp4 (eno1): activation: beginning transaction (timeout in 45 seconds)
Jul 26 17:41:42 PC1-Linux1 systemd[1]: Started Network Manager Script Dispatcher Service.
Jul 26 17:41:42 PC1-Linux1 nm-dispatcher[3535]: run-parts: failed to stat component /etc/network/if-post-down.d/avahi-daemon: No such file or directory
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option dhcp_lease_time => '3600'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option domain_name => 'REMOVED_DOMAIN'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option domain_name_servers => 'REMOVED_IP2 REMOVED_IP1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option expiry => '1595803302'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option host_name => 'user1_e4b97af22165'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option ip_address => 'REMOVED_IP51'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_broadcast_address => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_domain_name => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_domain_name_servers => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_domain_search => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_host_name => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_interface_mtu => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_ms_classless_static_routes => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_nis_domain => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_nis_servers => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_ntp_servers => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_rfc3442_classless_static_routes => '1'
Jul 26 17:41:42 PC1-Linux1 avahi-daemon[698]: Joining mDNS multicast group on interface eno1.IPv4 with address REMOVED_IP51.
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_root_path => '1'
Jul 26 17:41:42 PC1-Linux1 avahi-daemon[698]: New relevant interface eno1.IPv4 for mDNS.
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_routers => '1'
Jul 26 17:41:42 PC1-Linux1 avahi-daemon[698]: Registering new address record for REMOVED_IP51 on eno1.IPv4.
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_static_routes => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_subnet_mask => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_time_offset => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6713] dhcp4 (eno1): option requested_wpad => '1'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6714] dhcp4 (eno1): option routers => 'REMOVED_IP'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6714] dhcp4 (eno1): option subnet_mask => 'REMOVED_IP'
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6714] dhcp4 (eno1): state changed unknown -> bound
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6723] device (eno1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6736] device (eno1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6738] device (eno1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6740] manager: NetworkManager state is now CONNECTED_LOCAL
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6746] manager: NetworkManager state is now CONNECTED_SITE
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6746] policy: set 'Wired connection 1' (eno1) as default for IPv4 routing and DNS
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6750] device (eno1): Activation: successful, device activated.
Jul 26 17:41:42 PC1-Linux1 NetworkManager[704]: <info> [1595799702.6752] manager: NetworkManager state is now CONNECTED_GLOBAL
Jul 26 17:41:42 PC1-Linux1 whoopsie[1011]: [17:41:42] The default IPv4 route is: /org/freedesktop/NetworkManager/ActiveConnection/4
Jul 26 17:41:42 PC1-Linux1 whoopsie[1011]: [17:41:42] Not a paid data plan: /org/freedesktop/NetworkManager/ActiveConnection/4
Jul 26 17:41:42 PC1-Linux1 whoopsie[1011]: [17:41:42] Found usable connection: /org/freedesktop/NetworkManager/ActiveConnection/4
Jul 26 17:41:42 PC1-Linux1 whoopsie[1011]: [17:41:42] online
Jul 26 17:41:42 PC1-Linux1 systemd-resolved[656]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
Jul 26 17:41:43 PC1-Linux1 systemd-resolved[656]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
Jul 26 17:41:44 PC1-Linux1 systemd-resolved[656]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
Jul 26 17:41:45 PC1-Linux1 systemd-resolved[656]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
Output of free -h
total used free shared buff/cache available
Mem: 31Gi 1.3Gi 28Gi 52Mi 1.5Gi 29Gi
Swap: 2.0Gi 0B 2.0Gi
Output of sudo lshw -C memory
*-firmware
description: BIOS
vendor: Dell Inc.
physical id: 0
version: 2.5.0
date: 02/05/2020
capacity: 32MiB
capabilities: pci pnp upgrade shadowing cdboot bootselect edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification netboot uefi
*-memory
description: System Memory
physical id: 9
slot: System board or motherboard
*-bank:0
description: DIMM DDR4 Synchronous 2666 MHz (0.4 ns)
product: HMA82GU6JJR8N-VK
vendor: Hynix Semiconductor (Hyundai Electronics)
physical id: 0
serial: 72DB71AA
slot: DIMM1
width: 64 bits
clock: 2666MHz (0.4ns)
*-bank:1
physical id: 1
serial: 72DB71A7
slot: DIMM2
width: 64 bits
*-bank:2
description: [empty]
physical id: 2
slot: DIMM3
*-bank:3
physical id: 3
slot: DIMM4
*-cache:0
description: L1 cache
physical id: 14
slot: L1 Cache
capacity: 384KiB
capabilities: synchronous internal write-back unified
configuration: level=1
*-cache:1
description: L2 cache
physical id: 15
slot: L2 Cache
capacity: 1536KiB
configuration: level=2
*-cache:2
description: L3 cache
physical id: 16
slot: L3 Cache
capacity: 12MiB
configuration: level=3
*-memory UNCLAIMED
description: RAM memory
product: Cannon Lake PCH Shared SRAM
vendor: Intel Corporation
physical id: 14.2
bus info: pci@0000:00:14.2
version: 10
width: 64 bits
clock: 33MHz (30.3ns)
capabilities: pm cap_list
configuration: latency=0
resources: iomemory:400-3ff iomemory:400-3ff memory:4000114000-4000115fff memory:4000119000-4000119fff
No errors in memtest. Screenshots: screenshot1 screenshot2 screenshot3
