Like so many others, I've been trying to upgrade my OpenGL from 3.0 to 3.2, which was probably a terrible idea to begin with but here we are. Now my Ubuntu partition will not open properly and I'm currently running on the 2nd partition of my laptop containing PureOS. I think the problem comes from having tried to install ppa's, but I hope the community can help me out because I'm really stuck and I need my Ubuntu!
First some hardware/system details:
Machine: Librem 13
OS type: 64-bit
Graphics: IntelĀ® HD Graphics 620 (Kaby Lake GT2)
OS: Ubuntu 18.04.4 LTS
After logging in, I stay on the command line and it says xmodmap: unable to open display. Indeed echo $DISPLAY returns nothing. Running glxinfo returns "Error: unable to open display".
Here is the output for lshw for the graphics card:
sudo lshw -c video
*-display
description: VGA compatible controller
product: HD Graphics 620
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 02
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:125 memory:d0000000-d0ffffff memory:c0000000-cfffffff ioport:1c00(size=64) memory:c0000-dffff
Here's the output from apt policy. I tried to remove items not relevant here like those from "http://archive.ubuntu.com/ubuntu". Some of the ppa's were installed in an attempt to get to OpenGL 3.2 and should probably be removed:
apt policy
Package files:
100 /var/lib/dpkg/status
release a=now
500 http://ppa.launchpad.net/ubuntu-x-swat/updates/ubuntu bionic/main i386 Packages
release v=18.04,o=LP-PPA-ubuntu-x-swat-updates,a=bionic,n=bionic,l=Updates,c=main,b=i386
origin ppa.launchpad.net
500 http://ppa.launchpad.net/ubuntu-x-swat/updates/ubuntu bionic/main amd64 Packages
release v=18.04,o=LP-PPA-ubuntu-x-swat-updates,a=bionic,n=bionic,l=Updates,c=main,b=amd64
500 http://ppa.launchpad.net/oibaf/graphics-drivers/ubuntu bionic/main i386 Packages
release v=18.04,o=LP-PPA-oibaf-graphics-drivers,a=bionic,n=bionic,l=Updated Open Graphics Drivers - since 2011!,c=main,b=i386
500 http://ppa.launchpad.net/oibaf/graphics-drivers/ubuntu bionic/main amd64 Packages
release v=18.04,o=LP-PPA-oibaf-graphics-drivers,a=bionic,n=bionic,l=Updated Open Graphics Drivers - since 2011!,c=main,b=amd64
500 http://archive.canonical.com/ubuntu bionic/partner i386 Packages
release v=18.04,o=Canonical,a=bionic,n=bionic,l=Partner archive,c=partner,b=i386
origin archive.canonical.com
500 http://archive.canonical.com/ubuntu bionic/partner amd64 Packages
release v=18.04,o=Canonical,a=bionic,n=bionic,l=Partner archive,c=partner,b=amd64
And finally, lspci -v:
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 02)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.1 USB controller: Intel Corporation Device 9d30 (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
00:1f.5 Non-VGA unclassified device: Intel Corporation Device 9d24 (rev 21)
01:00.0 Network controller: Qualcomm Atheros AR9462 Wireless Network Adapter (rev 01)
- What's the problem causing xmodmap to fail?
- Should I remove the oibaf ppa's?
- Should I remove the ubuntu-x-swat ppa's?
Any help much appreciated!
(sorry if this has been discussed elsewhere in the forum, I searched on xmodmap and didn't find anything relevant)
EDIT: I didn't follow one tutorial in particular, but here's a brief recap:
GLX was returning a bad value so I did sudo apt install libnvidia-gl-440:i386 inspired by this issue with Steam: https://www.reddit.com/r/linuxquestions/comments/fu1228/steam_no_longer_launching_after_recent_ubuntu/
That seemed to make GLX work better:
glxinfo | grep "OpenGL version"
OpenGL version string: 3.0 Mesa 19.2.8
(At some I also edited /etc/X11/xorg.conf as described at the bottom of this page: https://public.confluence.arizona.edu/display/UAHPC/Visualization)
Since I need OpenGL 3.2, I added the ubuntu-x-swap ppa because I thought I was missing some updates, following http://ubuntuhandbook.org/index.php/2019/07/install-mesa-19-0-8-ubuntu-18-04-19-04/
Also added the oibaf repository too see if that would upgrade OpenGL, based on this 6 year old thread: How to update OpenGL Driver on Ubuntu 14.04 LTS
Sorry about the mess.
