12
I have a logitech wireless headset that can work in 2 different modes: High fidelity stereo audio (A2DP) without microphone and headset (HSP/HFP) with microfone.
The A2DP mode works, but when I try to switch to HSP/HFP the headset mutes and any background media freezes until I go back to A2DP.
This is the dsmeg output I get when I switch modes:
[   82.437350] ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x0000000FF) is beyond end of object (length 0xF) (20190816/exoparg2-393)
[   82.437366] No Local Variables are initialized for Method [GINF]
[   82.437367] Initialized Arguments for Method [GINF]:  (2 arguments defined for method invocation)
[   82.437368]   Arg0:   00000000bd65d180 <Obj>           Integer 00000000000000FF
[   82.437370]   Arg1:   00000000b898f041 <Obj>           Integer 0000000000000000
[   82.437374] ACPI Error: Aborting method \_SB.GINF due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
[   82.437378] ACPI Error: Aborting method \_SB.GADR due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
[   82.437381] ACPI Error: Aborting method \_SB.SGOV due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
[   82.437384] ACPI Error: Aborting method \_SB.CGWR due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
[   82.437387] ACPI Error: Aborting method \_SB.TBFP due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
[   82.437390] ACPI Error: Aborting method \_SB.WMTF.WMTF due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
[   82.441555] ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x0000000FF) is beyond end of object (length 0xF) (20190816/exoparg2-393)
[   82.441571] No Local Variables are initialized for Method [GINF]
[   82.441572] Initialized Arguments for Method [GINF]:  (2 arguments defined for method invocation)
[   82.441573]   Arg0:   000000007a385f3f <Obj>           Integer 00000000000000FF
[   82.441576]   Arg1:   00000000c7556536 <Obj>           Integer 0000000000000000
[   82.441579] ACPI Error: Aborting method \_SB.GINF due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
[   82.441583] ACPI Error: Aborting method \_SB.GADR due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
[   82.441586] ACPI Error: Aborting method \_SB.SGOV due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
[   82.441589] ACPI Error: Aborting method \_SB.CGWR due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
[   82.441592] ACPI Error: Aborting method \_SB.TBFP due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
[   82.441595] ACPI Error: Aborting method \_SB.WMTF.WMTF due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-529)
[   92.294393] input: Logitech Wireless Headset (AVRCP) as /devices/virtual/input/input41
PC specs are
Acer A515-54g (Bios v1.17 - lastest)
WIFI: Intel WIFI6 AX201
Intel Core i5 10210u
Dual boot with windows 10 (fast boot disabled)
EDIT:
ACPI errors can be caused by driver problems. The intel AX201 card is a very new one and the system does not detect it properly (as I asked in here). May be the issues are related somehow.
I've been experiencing this issue as well. There is a confirmed bug for pulseaudio and bluez. Please report that it affects you: https://bugs.launchpad.net/ubuntu/+source/pulseaudio/+bug/1878194
ysso
  • 86
I am experiencing the same issue just after moving from 19.10 to 20.04.
When the bluetooth headset is connected it is automatically configured as HSP/HSP but it does not work with this configuration (in 19.10 it did).
alcachi
  • 141
I finally got my Bluetooth headset work in HSP mode, which means the microphone works too.
1st step: be sure your bluetooth firmware
While when I was executing the command: sudo dmesg | grep -i bluetooth
I had a similar message of this:
bluetooth hci1: Direct firmware load for brcm/BCM20702A1-0b05-17cb.hcd failed with error -2
and after installing the broadcom-bt-firmware the same command return
[ 21.883358] Bluetooth: hci0: BCM20702A1 'brcm/BCM20702A1-0b05-17cb.hcd' Patch
2nd step: edit /etc/pulse/default.pa
and comment the ifexist and endif around module-bluetooth- so the policy and the discover load automatically
### Automatically load driver modules for Bluetooth hardware
#.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
#.endif
#.ifexists module-bluetooth-discover.so #load-module module-bluetooth-discover headset=ofono load-module module-bluetooth-discover #.endif
3rd step: purge and reinstall pulse
I followed this awsner
sudo apt-get --purge --reinstall install pulseaudio
and be sure in /etc/pulse/client.conf your autospawn = yes
than reboot
JOduMonT
  • 397
I had the same issue with my headphones in 2024 and the following commands solved it for me without requiring a reboot:
pulseaudio -k
After reconnecting with my headphones this issue was resolved.
PS: I was running Ubuntu 20.04 with kernel version 5.15.0 at the time.
And these were the relevant log message I saw when running journalctl -b:
systemd[3642]: Reached target Bluetooth.
m bluetoothd[1924]: Can't accept connection: Too many open files
bluetoothd[1924]: a2dp-sink profile connect failed for 38:28:5C:E6:4D:19: Input/output error
kernel: Bluetooth: hci0: SCO packet for unknown connection handle 0
melvio
  • 370
