I have been looking for a solution to this problem for quite some time but I haven't managed to find any fixes.
I have an Asus ROG Strix G731GT laptop running a dual-boot of Windows 10 & Ubuntu 20.04 LTS. The laptop's built-in keyboard has RGB lightning.
The problem is that while on Windows I can easily control the lights using the Armoury Crate and Asus Aura apps from the Microsoft Store, I cannot manage to find an alternative to these programs for Linux.
Not even the key combinations (FN + arrow keys) that are used to control the RGB's brightness and pattern work.
Does anyone have a clue as to how I can control the RGB on my keyboard? All the solutions I have found online are for external keyboards, but I couldn't find anything related to the built-in keyboard.
(Note: In this case my keyboard's RGB does function, but I just can't change the color or the brightness of the RGB.)
SharpeN
  • 143
I was able to control the lights using a repository called 'rogauracore' (https://github.com/wroberts/rogauracore). The command syntax is really easy and it works perfectly.
SharpeN
  • 143
In your linux terminal paste the following commands (source- https://github.com/wroberts/rogauracore):
sudo apt install libusb-1.0-0 libusb-1.0-0-dev
VERSION=1.4
curl -LOs https://github.com/wroberts/rogauracore/releases/download/$VERSION/rogauracore-$VERSION.tar.gz
tar xf rogauracore-$VERSION.tar.gz
cd rogauracore-$VERSION/
./configure
make
sudo make install
and then just run the command for your preferred colour, for eg:
sudo rogauracore single_static 0000ff
Hope it helps.
Note:
. Install g++ prior to running the ./configure command.
. It may happen that you have to wake up the keyboard, run sudo rogauracore initialize_keyboard for that and then try setting the colour.
