38
I am trying to upgrade from Ubuntu 19.10 to Ubuntu 20.04 but when I run the update, in the second stage this error pops:
Invalid package information
After updating your package information, the essential package 'ubuntu-minimal' could not be located. This may be because you have no official mirrors listed in your software sources, or because of excessive load on the mirror you are using. See /etc/apt/sources.list for the current list of configured software sources. In the case of an overloaded mirror, you may want to try the upgrade again later.
Pablo Bianchi
  • 17,371
A45
  • 503
6 Answers6
69
The actual solution is to run RELEASE_UPGRADER_ALLOW_THIRD_PARTY=1 do-release-upgrade instead of the normal upgrade command.
There's no need to manually mess with sources.list (which doesn't work anyway). Just prevent the OS from disabling third-party sources, because they include packages that the OS needs in order to complete the upgrade.
Source: a comment in https://www.digitalocean.com/community/questions/cannot-update-to-19-04-the-essential-package-ubuntu-minimal-could-not-be-located-2
17
I had the same problem. The solution was to add the official sources to the apt sources.list.
  1. Make a copy of your source list:
    sudo cp /etc/apt/sources.list /etc/apt/sources.list.bak
  2. Get the official sources for Ubuntu 19.10 from sources.list › Wiki › ubuntuusers.de
    deb http://de.archive.ubuntu.com/ubuntu eoan main restricted universe multiverse
    deb http://de.archive.ubuntu.com/ubuntu eoan-updates main restricted universe multiverse
    deb http://de.archive.ubuntu.com/ubuntu eoan-security main restricted universe multiverse
    deb http://de.archive.ubuntu.com/ubuntu eoan-backports main restricted universe multiverse
  3. Open the list and add these lines at the end
    sudo nano /etc/apt/sources.list
  4. Update sources and install all available updates for 19.10 and reboot your system:
    sudo apt-get update
    sudo apt-get upgrade
    sudo apt-get dist-upgrade
    sudo apt-get autoremove
    sudo reboot
  5. Ensure you have the lts path at the update-manager:
    $ cat /etc/update-manager/release-upgrades
    Prompt=lts
  6. If you upgrade over ssh: ensure your firewall allows ssh access over port 1022 (recovery-ssh-port). I didn't need to use port, it is just in case.
  7. Run the Upgrade
    sudo do-release-upgrade
Kulfy
  • 18,154
Christof
  • 194
I was having this problem on a DigitalOcean droplet. The fix from VivienM seems to have done the trick for me.
While do-release-update was paused at this message:
Third party sources disabled
Some third party entries in your sources.list were disabled. You can re-enable them after the upgrade with the ‘software-properties’ tool or your package manager.
To continue please press [ENTER]
After you see this message go to /etc/apt/sources.list and uncomment all the references to mirrors.digitalocean.com. Then press ENTER to resume the installation.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
This sorted it for me. It seems the automatic source.list relying on mirrors.txt functionality did not work for some reason. What comes to the archive mirror list above, the URL is:
http://<country-code>.archive.ubuntu.com/ubuntu/
In my case both RELEASE_UPGRADER_ALLOW_THIRD_PARTY=1 do-release-upgrade and do-release-upgrade --allow-third-party didn't work.
I had to manually convert the entries from /etc/apt/source.list file from
deb mirror://mirrors.ubuntu.com/mirrors.txt focal main restricted
to real repo URL like
deb http://ubuntu.task.gda.pl/ubuntu focal main restricted
You need to run sudo apt-get update after the change.
Then I was able to upgrade from 20.04 to 22.04 without any errors.
-2
I had a similar issue when upgrading 16.04 to 18.04.
It started upgrading when I added these lines to my sources.list:
deb http://archive.ubuntu.com/ubuntu/ xenial main universe multiverse
deb http://archive.ubuntu.com/ubuntu/ xenial-security main universe multiverse
See also https://www.linode.com/community/questions/17813/errors-when-upgrading-from-1604-to-1804#answer-68979
srmrco
