Before starting PulseEffects, my audio output to the speakers/headphones is fine. Once I start PulseEffects (with no output effects toggled), no audio is heard from anything. Closing PulseEffects does not remedy the issue; I have to restart Ubuntu to regain audio out. Any ideas?
neofetch screen
NathanH
  • 85
I had the same problem. In my case, incorrect pulse config made that problem.
I fixed that problem by resetting that configuration by:
  1. Rename pulse folder located at $HOME/.config to any name (just for backup the original)
  2. Open your terminal and type the commands below:
    pulseaudio --kill
    pulseaudio --start
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
Got the same problem on t430 also all works without pulse effects when i start it there is no output from pulse audio service even if the apps are playing into pulseeffects device. kill -9 pgrep pulseeffects kills it and fixes the audio after closing.
JWaz
I got the same problem on 20.04.
pulseaudio --kill
pulseaudio --start
resolved my issue without restarting the ubuntu.
