16
I tried adding a new user and it works, I can login just fine with that user. So I tried removing (renamed it) my home directory, and that also fixes it.
Then I tried removing the .config/monitors.xml file, that didn't help. So now I have to try each file/directory in there one by one... but there are hundreds.
Any ideas on what specific files I should try moving/deleting to make my account work again?
Ivan
  • 475
7 Answers7
11
I thought it was gonna take hours but I found .config/dconf/user to be the culprit. Removing that file restored my ability to login without ending up in a black screen.
Ivan
  • 475
I had this problem, and found out that it was because of my radeon driver. According to Can't Log In or Black Screen After Logging In with Ubuntu I blacked list it and everything worked just fine.
Andromeda
  • 131
Same as Andromeda above, I followed the same link above Black Screen Or Login Issues Ubuntu 22.04.
Couldn't Blacklist Radeon graphics card. My permission were denied for some reason.
Anyways, followed making another test user to check if test user is working fine. Then moved the old configuration files.
Roy
  • 51
For me it was .config/dconf/user was read-only. I populated it in the kickstart, so yes, not ubuntu, but still gnome - don't hate. It is still relevant.
It was read-only in /etc/skel so got copied into the user's home as read-only. Setting the /etc/skel/.config/dconf/user file to u+rw (or 600) solved the issue.
Symptom was the GUI would show after login for about a second, then go to a black screen. Pressing Ctrl-C multiple times caused the system to return to the Login screen.
I had the same problem. I was able to log in to the recovery mode properly, so the problem was definitely in the Nvidia drivers used in the normal mode as the recovery mode uses the Nouveau drivers.
So, upon restart, drop into the root shell prompt (either via the GRUB menu or CTRL+ALT+Fn) (Fn can be F1 to F6) and run:
sudo ubuntu-drivers autoinstall
The above command will autoinstall the drivers suited to your machine and update them. Then, verify it using:
nvidia-smi
And, run:
sudo reboot
Now, you'll be able to log back in properly to your desktop with updated drivers.
Black screen or mouse/touchpad freeze problem after login is resolved with the following actions:
  1. Mask the NetworkManager-wait-online service => https://askubuntu.com/a/1166492/1761962
  2. Edit the system.conf file at /etc/systemd folder => https://askubuntu.com/a/1160776/1761962
  3. Display hidden Startup Apps, then uncheck unnecessary startup apps => https://help.ubuntu.com/community/ShowHiddenStartupApplications
  4. Reconfigure gdm3 => https://askubuntu.com/a/1260286
It needs additional commands for the unnecessary startup services.
systemctl mask org.gnome.SettingsDaemon.Smartcard.service --user
systemctl mask org.gnome.SettingsDaemon.Wacom.service --user
systemctl mask org.gnome.SettingsDaemon.Wwan --user
systemctl mask org.gnome.SettingsDaemon.UsbProtection --user
If cups service is not needed, stop & disable it also.
  1. Stop & disable snap cups service
    sudo snap stop cups
    sudo snap disable cups
  2. And also stop & disable CUPS systemd service
    Easy way is using mission center, in Services tab, type cups on your keyboard, then stop & disable it
And clean unnecessary system files using BleachBit. Installl the gui utility by sudo apt install bleachbit
PS. The problem is also solved by clicking the menu in the upper right corner of the login screen, turning off WiFi, Airplane Mode, and Bluetooth, and then entering the password to log in.
kvmb11
  • 61
tldr If you're using a virtual machine with a 4k monitor, try logging in on a 1080 monitor or try dropping your display settings down to 1080.
Didn't begin after upgrading, but suddenly I also got a black screen after logging in.
Moving virtualbox to my other monitor before logging in fixes the issue. I haven't narrowed it down to determine if it's an issue with virtualbox, or ubuntu. Either way, I'm assuming it has something to do with the fact that I changed Monitor 1 to use 4k--Monitor II is still 1080.
Mars
  • 101
