OS: Ubuntu 20.04 LTS; Graphics: GeForce GTX 1060 6GB/PCle/SSE2; Monitor: ASUS PB287Q; Port: Display Port;
I just installed Ubuntu 20.04 LTS and attempted to apply fractional scaling to the display.
When changing the display scale option to 150%, the screen went blank/black for roughly 10 seconds and then came back and showed an error, without the scaling applied.
With the fractional scale option still selected, I changed to 200%, and then the screen went blank and stayed that way.
After turning my PC off and on again, I can login normally, but after logging in, the screen turns blank again and I can't do anything.
I could just re-install the system, but I'm hoping for a solution in case I face this problem again in the future.
leto
  • 171
5 Answers5
Just to add a bit more to Wagner Michael's answer:
The following was performed successfully on Ubuntu 20.04:
  1. Boot into Ubuntu Recovery mode.
  2. Select "Drop into root user"
  3. sudo su - [Insert your username]
  4. gsettings get org.gnome.mutter experimental-features
    • Output should be = "['x11-randr-fractional-scaling']"
  5. gsettings set org.gnome.mutter experimental-features "[]"
  6. reboot
Fixed.
Minimul
  • 131
Disabling fractional scaling via command line has done the job for me:
Before experimental-features was set to "['x11-randr-fractional-scaling']" in my case.
Either you go into a different tty at boot (Ctrl+Alt+F2) or you do it from recovery mode and dropping into the root prompt. Either way, all you have to do is type:
rm .config/monitors.xml
To get rid of the fractional scaling config
Gerard
  • 151
If you get an error (as I did ) when gsettings set ...
to the effect cannot launch autolaunch d-bus without x-11 DISPLAY use
dbus-launch gsettings set org.gnome.mutter experimental-features "[]"
Go into Terminal at the login screen, remove the file .config/dconf/user and then sudo reboot. I think it resets the display settings to default.
This fixed my problem -- setting a fractional scaling and then black screen after login.
See Black screen after logging in, after upgrading to 20.04
yueqiw
