I tried Ubuntu Vanila, Mate and Kylin (all same version 20.04) still the same. It plays fine with the inbuilt speakers but when a headphone is plugged in there is no audio. In the speaker settings it changes from speaker to headphones but doesn't play. Then reinstalled 19.10 and now audio is fine.
Try in your terminal
sudo apt update && sudo apt install alsamixer- run
alsamixerin your terminal. - press arrow right til you go to HEADPHONES bar.
- press
Mto unmute. - press up/down to adjust the volume.
- press Esc to exit alsamixer.
- run
sudo alsactl storein your terminal to store your settings earlier.
- 81
Ubuntu, headphone not muted in 'alsamixer', volume is high, still now sound!
Please try this, if your Ubuntu is using snd hda intel.
Open Terminal (If you don't know where Terminal is, click Show Application in Unity, type Terminal, it should appear, click it open.)
In Terminal type the command, sudo nautilus. Give your password as asked. This should have opened your file browser with access to root filesystem. Look for etc folder.
Inside etc folder, find modprob.d folder.
In modprobe.d find the file alsa-base.cof (or alsa.conf instead, if alsa-base.conf is not there.)
Copy the following two lines and paste as the last two lines in alsa configuration file you have just opened.
options snd-hda-intel model=headset-mode options snd-hda-intel model=dell-headset-multi
Click 'Save' in alsa or alsa-base.
Restart the system. Plugin your headphone, microphone.
Now Ubuntu should be able to auto-detect headphone and microphone.
- 21
Use pavucontrol and enable the microphone audio (and speaker). If the microphone is disabled the speaker doesn't work.
I don't know why this happens, but the above fixes the problem.
- 16,703
20.04 headphones didn't work for me either. BUT after I finished doing another partial upgrade of packages evertyhing worked. Apparently something was missing / upgrade was not completely finished. Now headphones works just like 19.04.
- 223
After installing Ubuntu 20.04 LTS on my new Dell Vostro 3490 (2019) my 3.5 mm audio jack was not working. This is what worked for me:
- Make sure Headphones built-in audio is selected in Ubuntu's Sound Settings in the Output panel.
- Run alsamixer to unmute the headphone audio (as in @tanhernandez answer):
# alsamixer
- Save alsamixer settings:
# sudo alsactl store
- Run:
# lsactl restore
If you are still having problems, this worked for me as well as alot of people with "gaming" laptops: [link][1]
Pasting the answer that worked for me
so after having this issue with beautiful, but already annoying 20.04 I've found a solution in another post at superuser. In my case what helped me was:
cat /proc/asound/card*/codec* | grep Codec
to get the Audio Codec for your machine model. In my case I saw Audio (ex: Codec: Realtek ALC233) & Video (ex: Codec Nvidia GPU 94 HDMI/DP) codecs there.
Go to www.kernel.org and look up the version of the codec, and get the full name of it. In my case: Realtek ALC233 -> alc233
Create/update a file under /etc/modprobe.d/alsa-base.conf, and add this line: options snd-hda-intel model=alc233-eapd
while replacing model with yours
Reboot the machine.
It helped me, so let me know if that works for you. Cheers!
