19
My screen resolution is 2560x1440 and I am using fractional scaling at 125%.
Steam fonts are unreadable (see the screenshot and compare with the size of the Chrome icon).
Vincenzo Pii
  • 1,909
6 Answers6
17
If you want to start steam with scaled UI from launchpad, you can set GDK_SCALE=2 (as mentioned in the accepted solution) in steam.desktop file (in my case it is located in /usr/share/applications).
First, open the file in your favourite text editor (e.g. gedit). You might need superuser privileges:
gedit /usr/share/applications/steam.desktop
Then change the Exec entry value to:
Exec=sh -c 'GDK_SCALE=2 /usr/games/steam %U'
Note: your steam path can be different to mine (/usr/games/steam). Just use the path from your Exec entry.
myrs
  • 311
10
Find the bin_steam.sh:
$ which steam
// >> /usr/bin/steam
$ ls -la /usr/bin/steam
// >> lrwxrwxrwx 1 root root 25 Jul 29  2020 /usr/bin/steam -> ../lib/steam/bin_steam.sh
$ ls -la /usr/lib/steam/bin_steam.sh
// >> -rwxr-xr-x 1 root root 5946 Jun 21 14:26 /usr/lib/steam/bin_steam.sh
Edit bin_steam.sh:
$ sudo gedit /usr/lib/steam/bin_steam.sh
Add at the beginning export GDK_SCALE=2:
File changes
Run Steam as usual and see the changes ;)
If you start Steam from a terminal with the command GDK_SCALE=2 steam it seems to work.
I found the answer on a Manjaro help page.
For anyone stumbling into this in the future.
If you find the default UI too small and GDK_SCALE=2 too big, you can apply a zoom to the steam UI instead for 150%, 125% etc. Here's how for Ubuntu based distros for example:
(make sure your directories are the same)
mkdir -p ~/.steam/steam/skins/steamzoom/resource/styles
cp ~/.steam/steam/resource/styles/steam.styles ~/.steam/steam/skins/steamzoom/resource/styles/steam.styles
echo ":root { zoom: 1.5; }" > ~/.steam/steam/skins/steamzoom/resource/webkit.css
You can later apply the last command again to change the zoom size to your preference.
I personally use 1.25 (125%).
Afterwards go to your Steam Settings -> Interface -> select the new "steamzoom" skin you just created and apply it.
This can also be applied to existing steam skins, for example Adwaita skin you'd only need to
echo ":root { zoom: 1.25; }" > ~/.steam/steam/skins/Adwaita/resource/webkit.css
I had the same issue with Steam and Spotify. Changed the fractional scaling back to 100% from 125% and the fonts went back to being readable.
Freddy
Start steam client adding parameters -w 1368 -h 768 or whatever size you want, always smaller than your monitor resolution. The smaller value, the bigger overall size of steam client, including fonts.
You may add parameters to your Windows shortcut, it works in Linux shortcuts too.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
