My OS: Ubuntu 20.04LTS
python --version: Command python not found
python3 --version: Python 3.8.2
Kazam was working well. I regularly upgrade packages using sudo apt-get update; sudo apt-get upgrade commands. I also update OS using update-manager -c command. So, one day kazam has stopped working. It gives the following error:
/usr/bin/kazam:32: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded.
from gi.repository import Gtk
WARNING Kazam - Failed to correctly detect operating system.
Traceback (most recent call last):
File "/usr/bin/kazam", line 147, in <module>
from kazam.app import KazamApp
File "/usr/lib/python3/dist-packages/kazam/app.py", line 36, in <module>
from kazam.backend.prefs import *
File "/usr/lib/python3/dist-packages/kazam/backend/prefs.py", line 30, in <module>
from kazam.backend.webcam import Webcam
File "/usr/lib/python3/dist-packages/kazam/backend/webcam.py", line 24, in <module>
from gi.repository import GObject, GUdev
File "/usr/lib/python3/dist-packages/gi/importer.py", line 132, in load_module
raise ImportError('cannot import name %s, '
ImportError: cannot import name GUdev, introspection typelib not found
I had run sudo ln -s /usr/bin/python3 /usr/bin/python for a different purpose. After some days the following happened: (Don't know how the system installed this python version)
python --version: Python 2.7.18rc1
Later I deleted the symbolic link too. So, now python command outputs Command not found.
