I am trying to install libcairo2-dev in a Ubuntu 18.04.2 LTS Bionic.
I run :
    $ sudo apt-get install libcairo2-de
    Reading package lists... Done
    Building dependency tree
     libcairo2-dev : Depends: libx11-dev but it is not going to be installed
                     Depends: libxrender-dev (>= 0.6) but it is not going to be installed
                     Depends: libxext-dev but it is not going to be installed
                     Depends: libxcb1-dev (>= 1.6) but it is not going to be installed
                     Depends: libxcb-render0-dev (>= 1.6) but it is not going to be installed
                     Depends: libxcb-shm0-dev but it is not going to be installed
Then I try
    $ sudo apt-get autoclean
    $ sudo apt-get -f install
    0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
    $ sudo apt-get -u dist-upgrade
    Calculating upgrade... Done
But nothing works,
My sources.list :
    cat /etc/apt/sources.list
    deb http://archive.ubuntu.com/ubuntu bionic main universe restricted multiverse
    deb-src http://archive.ubuntu.com/ubuntu bionic main universe restricted multiverse #Added by software-properties
    deb http://security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
    deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
Then I tried what guiverc and StrabagISS_Krall suggested
sudo apt-get update
Hit:1 http://ppa.launchpad.net/klaus-vormweg/awesome/ubuntu bionic InRelease
Hit:2 http://archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://security.ubuntu.com/ubuntu bionic-security InRelease
Ign:4 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:5 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:6 http://dl.google.com/linux/chrome/deb stable Release
Then ,
sudo apt full-upgrade
And then ,
sudo apt-get install libcairo2-dev
In fact, I check the version of each dependency they are there with the last version.
$ apt-cache showpkg libx11-dev
Package: libx11-dev
Versions:
2:1.6.4-3ubuntu0.2 (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_bionic-updates_main_binary-amd64_Packages)
$ apt-cache showpkg libxrender-dev
Package: libxrender-dev
Versions:
1:0.9.10-1 (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_bionic_main_binary-amd64_Packages)
N0rbert suggested to recreate the repository list, but when I run sudo apt-get update none of the repositories fail to fetch, see above. But anyway I tried to recreate the repository list as suggest in How do I restore the default repositories? but did not work.
I faced the same problem too while installing libcairo2-dev, whence I found that one of the dependencies did not match the version it required--
libxau-dev : Depends: libxau6 (= 1:1.0.8-1) but 1:1.0.8-1ubuntu1 is to be installed
So, I tried installing a specific version--
$ sudo apt install libaux6=1:1.0.8-1
wherein I got some package removal and one downgrading request--
The following packages were automatically installed and are no longer required:
  libapparmor1:i386 libasn1-8-heimdal:i386 libasound2:i386 libasyncns0:i386 libatk1.0-0:i386 libatomic1:i386 libavahi-client3:i386
  libavahi-common-data:i386 libavahi-common3:i386 libbsd0:i386 libcap2:i386 libcapi20-3 libcapi20-3:i386 libcdparanoia0:i386 libcups2:i386
  libdatrie1:i386 libdbus-1-3:i386 libdrm-amdgpu1:i386 libdrm-intel1:i386 libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libedit2:i386
  libelf1:i386 libexif12:i386 libexpat1:i386 libffi6:i386 libflac8:i386 libfontconfig1:i386 libfreetype6:i386 libgl1-mesa-dri:i386
  libglapi-mesa:i386 libglib2.0-0:i386 libglvnd0:i386 libgmp10:i386 libgnutls30:i386 libgphoto2-port12:i386 libgraphite2-3:i386 libgsm1:i386
  libgssapi-krb5-2:i386 libgssapi3-heimdal:i386 libgstreamer-plugins-base1.0-0:i386 libgstreamer1.0-0:i386 libharfbuzz0b:i386
  libhcrypto4-heimdal:i386 libheimbase1-heimdal:i386 libheimntlm0-heimdal:i386 libhogweed4:i386 libhx509-5-heimdal:i386 libicu60:i386
  libidn2-0:i386 libieee1284-3:i386 libjack-jackd2-0:i386 libjbig0:i386 libjpeg-turbo8:i386 libjpeg8:i386 libk5crypto3:i386 libkeyutils1:i386
  libkrb5-26-heimdal:i386 libkrb5-3:i386 libkrb5support0:i386 liblcms2-2:i386 libldap-2.4-2:i386 libllvm10:i386 libltdl7:i386 libmpg123-0:i386
  libnettle6:i386 libogg0:i386 libopenal1:i386 libopus0:i386 liborc-0.4-0:i386 libosmesa6:i386 libp11-kit0:i386 libpango-1.0-0:i386
  libpangoft2-1.0-0:i386 libpcap0.8:i386 libpciaccess0:i386 libpixman-1-0:i386 libpng16-16:i386 libroken18-heimdal:i386 libsamplerate0:i386
  libsasl2-2:i386 libsasl2-modules:i386 libsasl2-modules-db:i386 libsensors4:i386 libsndfile1:i386 libsndio6.1:i386 libspeexdsp1:i386
  libsqlite3-0:i386 libssl1.1:i386 libstdc++6:i386 libsystemd0:i386 libtasn1-6:i386 libthai0:i386 libtiff5:i386 libudev1:i386 libunistring2:i386
  libusb-1.0-0:i386 libv4l-0:i386 libv4lconvert0:i386 libvisual-0.4-0:i386 libvorbis0a:i386 libvorbisenc2:i386 libwayland-client0:i386
  libwayland-cursor0:i386 libwayland-egl1:i386 libwebp6:i386 libwind0-heimdal:i386 libwrap0:i386 libx11-xcb1:i386 libxdmcp6:i386
  libxkbcommon0:i386 libxml2:i386 libxshmfence1:i386 libxslt1.1:i386 ocl-icd-libopencl1:i386 wine-stable-amd64
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
  adobereader-enu:i386 gstreamer1.0-plugins-base:i386 libasound2-plugins:i386 libcairo2:i386 libgd3:i386 libgdk-pixbuf2.0-0:i386 libgl1:i386
  libgl1-mesa-glx:i386 libglu1-mesa:i386 libglx-mesa0:i386 libglx0:i386 libgphoto2-6:i386 libgtk2.0-0:i386 libpangocairo-1.0-0:i386
  libpulse0:i386 libsane1:i386 libsdl2-2.0-0:i386 libtheora0:i386 libx11-6:i386 libxau6:i386 libxcb-dri2-0:i386 libxcb-dri3-0:i386
  libxcb-glx0:i386 libxcb-present0:i386 libxcb-render0:i386 libxcb-shm0:i386 libxcb-sync1:i386 libxcb1:i386 libxcomposite1:i386 libxcursor1:i386
  libxdamage1:i386 libxext6:i386 libxfixes3:i386 libxi6:i386 libxinerama1:i386 libxpm4:i386 libxrandr2:i386 libxrender1:i386 libxss1:i386
  libxxf86vm1:i386 steam:i386 wine-stable wine-stable-i386:i386 winehq-stable
The following packages will be DOWNGRADED:
  libxau6
0 upgraded, 0 newly installed, 1 downgraded, 44 to remove and 1 not upgraded.
Need to get 7,513 kB of archives.
After this operation, 29.0 MB of additional disk space will be used.
Do you want to continue? [Y/n]
I opted for "Y", followed by--
$ sudo apt install libcairo2-dev
...and Voila... that seems to have fixed the problem !
Partha D.
  • 111
You need to update your system first. Please try:
sudo apt update
BulletBob
  • 1,830
