I'm attempting to run the Amateur (ham) radio program qsstv on Ubuntu 19.10, on a new Dell PC, Optiplex 5055 with an AMD PRO A10-9700 R7 CPU with 10 compute cores (4C+6G) and 8GB RAM. swapon NAME TYPE SIZE USED PRIO /dev/sda5 partition 14.9G 4M -2 free total used free shared buff/cache available Mem: 7082736 2973652 491932 76956 3617152 3732324 Swap: 15625212 4096 15621116
lscpu Architecture: x86_64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian Address sizes: 48 bits physical, 48 bits virtual CPU(s): 4 On-line CPU(s) list: 0-3 Thread(s) per core: 2 Core(s) per socket: 2 Socket(s): 1 NUMA node(s): 1 Vendor ID: AuthenticAMD CPU family: 21 Model: 101 Model name: AMD PRO A10-9700 R7, 10 COMPUTE CORES 4C+6G Stepping: 1 Frequency boost: enabled CPU MHz: 1396.819 CPU max MHz: 3500.0000 CPU min MHz: 1400.0000 BogoMIPS: 6986.46 Virtualization: AMD-V L1d cache: 64 KiB L1i cache: 192 KiB L2 cache: 2 MiB NUMA node0 CPU(s): 0-3 Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled v ia prctl and seccomp Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization Vulnerability Spectre v2: Mitigation; Full AMD retpoline, IBPB conditiona l, STIBP disabled, RSB filling Vulnerability Tsx async abort: Not affected Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtr r pge mca cmov pat pse36 clflush mmx fxsr sse s se2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtsc p lm constant_tsc rep_good acc_power nopl nonst op_tsc cpuid extd_apicid aperfmperf pni pclmulq dq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe p opcnt aes xsave avx f16c lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnow prefetch osvw ibs xop skinit wdt lwp fma4 tce n odeid_msr tbm topoext perfctr_core perfctr_nb b pext ptsc mwaitx cpb hw_pstate ssbd ibpb vmmcal l fsgsbase bmi1 avx2 smep bmi2 xsaveopt arat np t lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthresho ld avic vgif overflow_recov
Every step of the way in this program, from the opening splash screen to clicking on different tabs and menu options in the program, there is a long 60-120 second wait before anything happens. Many other programs run like the wind on this PC, so I'm not sure what is going on here.
I tried to just mv the /home/user/sstv dir, and start with a new config, no luck. If I run this in a windows while going into the config menu, and attempting to restart and cat interface:
sudo journalctl -f -- Logs begin at Thu 2020-04-16 01:30:53 CDT. -- Apr 22 19:30:01 hamshack CRON[4055]: pam_unix(cron:session): session closed for user root Apr 22 19:32:53 hamshack systemd1: Started Run anacron jobs. Apr 22 19:32:53 hamshack anacron[4080]: Anacron 2.3 started on 2020-04-22 Apr 22 19:32:53 hamshack anacron[4080]: Normal exit (0 jobs run) Apr 22 19:32:53 hamshack systemd1: anacron.service: Succeeded. Apr 22 19:37:45 hamshack sudo[4169]: john : TTY=pts/1 ; PWD=/home/john ; USER=root ; COMMAND=/usr/bin/lshw Apr 22 19:37:45 hamshack sudo[4169]: pam_unix(sudo:session): session opened for user root by (uid=0) Apr 22 19:37:48 hamshack sudo[4169]: pam_unix(sudo:session): session closed for user root Apr 22 19:39:21 hamshack sudo[4197]: john : TTY=pts/1 ; PWD=/home/john ; USER=root ; COMMAND=/usr/bin/journalctl -f Apr 22 19:39:21 hamshack sudo[4197]: pam_unix(sudo:session): session opened for user root by (uid=0)
