Using Ubuntu 19.10 I have 3 output devices in Settings -> Sound -> Output-Device:
  • HDMI (monitor)
  • S/PDIF (onboard)
  • Headphone (onboard)
AMD 2400G, Asus PRIME B450M-A
I need this priority:
  1. Headphones
  2. HDMI
  3. S/PDIF (unused)
So it should switch to headphones if plugged in, otherwise HDMI.
Now it starts with HDMI, no matter if headphones is plugged in. When I select headphone, and later unplug headphone, it falls back to S/PDIF which is not used at all.
Shouldn't the GUI offer a draggable list to order my preferences? I kinda like the simplicity of Gnome GUI, but sometimes it's too minimal.
How do I set priority?
Janghou
  • 6,035
I don't know how you would set priority, but there is a way to shut off the S/PDIF. Open Pulse Audio Volume Control and turn off S/PDIF. It should disappear from the Volume Settings list. (found here - https://askubuntu.com/a/1186737/150363)
As for the headphones bit, you may still have to manually choose them, but when you unplug (if you followed the above), it should go back to HDMI.
Syd
  • 282
