As reported on the subject, I've failed installing the latest stable wine version because a broken package has accurred in my computer. Particularly, after typing
sudo apt install wine-stable
the following message have appeared
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: wine-stable : Depends: wine-stable-i386 (= 7.0.1~focal-1) Depends: wine-stable-amd64 (= 7.0.1~focal-1) but 4.0~bionic is to be installed E: Unable to correct problems, you have held broken packages.
Acording with what I've found here, In what follows more details of what I did.
Here is my system
lsb_release -a
LSB Version: core-9.20170808ubuntu1-noarch:printing-9.20170808ubuntu1-noarch:security-9.20170808ubuntu1-noarch Distributor ID: LinuxMint Description: Linux Mint 19.2 Tina Release: 19.2 Codename: tina
The following packages were automatically installed and are no longer required: bridge-utils browser-plugin-freshplayer-pepperflash containerd golang-docker-credential-helpers gstreamer1.0-plugins-base:i386 libasn1-8-heimdal:i386 libatomic1:i386 libbonobo2-0 libbonobo2-common libbonoboui2-0 libbonoboui2-common libboost-signals1.65.1 libcap2:i386 libcapi20-3 libcapi20-3:i386 libcdparanoia0:i386 libdrm-amdgpu1:i386 libdrm-intel1:i386 libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libedit2:i386 libegl-mesa0:i386 libegl1:i386 libelf1:i386 libevent-pthreads-2.1-6 libexif12:i386 libgbm1:i386 libgd3:i386 libgl1:i386 libgl1-mesa-dri:i386 libgl1-mesa-glx:i386 libglapi-mesa:i386 libglu1-mesa:i386 libglvnd0:i386 libglx-mesa0:i386 libglx0:i386 libgnome-2-0 libgnome-keyring-common libgnome-keyring0 libgnome2-common libgnomeui-0 libgnomeui-common libgnomevfs2-0 libgnomevfs2-common libgphoto2-6:i386 libgphoto2-port12:i386 libgsm1:i386 libgssapi3-heimdal:i386 libgstreamer-plugins-base1.0-0:i386 libgstreamer1.0-0:i386 libgtksourceview2.0-0 libgtksourceview2.0-common libhcrypto4-heimdal:i386 libheimbase1-heimdal:i386 libheimntlm0-heimdal:i386 libhx509-5-heimdal:i386 libicu60:i386 libieee1284-3:i386 libkrb5-26-heimdal:i386 liblcms2-2:i386 libldap-2.4-2:i386 libllvm10:i386 libllvm8:i386 libmpg123-0:i386 libodbc1:i386 libopenal1:i386 libopus0:i386 liborbit-2-0 liborc-0.4-0:i386 libosmesa6:i386 libpcap0.8:i386 libpciaccess0:i386 libroken18-heimdal:i386 libsane1:i386 libsasl2-2:i386 libsasl2-modules:i386 libsasl2-modules-db:i386 libsdl2-2.0-0:i386 libsensors4:i386 libsndio6.1:i386 libsqlite3-0:i386 libssl1.1:i386 libtheora0:i386 libusb-1.0-0:i386 libv4l-0:i386 libv4lconvert0:i386 libvisual-0.4-0:i386 libwayland-client0:i386 libwayland-cursor0:i386 libwayland-egl1:i386 libwayland-egl1-mesa:i386 libwayland-server0:i386 libwebp6:i386 libwind0-heimdal:i386 libx11-xcb1:i386 libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386 libxcb-sync1:i386 libxcb-xfixes0:i386 libxkbcommon0:i386 libxml2:i386 libxpm4:i386 libxshmfence1:i386 libxslt1.1:i386 libxss1:i386 libxxf86vm1:i386 lyx-common ocl-icd-libopencl1:i386 pigz python-asn1crypto python-backports.ssl-match-hostname python-cached-property python-certifi python-cffi-backend python-cryptography python-docker python-dockerpty python-dockerpycreds python-docopt python-funcsigs python-functools32 python-idna python-ipaddress python-jsonschema python-mock python-openssl python-pbr python-requests python-texttable python-urllib3 python-websocket python-yaml runc ubuntu-fan wine-stable wine-stable-amd64 wine-stable-i386:i386 Use 'sudo apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 465 not upgraded.
Here the system answer when I remove wine
$ sudo apt remove wine winehq-stable
Virtual packages like 'wine' can't be removed
Package 'winehq-stable' is not installed, so not removed
Here the system answer when I try to install wine again
$ sudo apt install wine-stable
Can you help me to properly understand what does it say and how can I fix it, please?
32-bit is not enabled on your system.
Do:
sudo dpkg --add-architecture i386
sudo add-apt-repository universe
sudo apt update
sudo apt full-upgrade
wineboot
or you can install winehq's wine:
For ubuntu 22.10:
sudo wget -NP /etc/apt/sources.list.d/ https://dl.winehq.org/wine-builds/ubuntu/dists/kinetic/winehq-kinetic.sources
sudo apt update
sudo mkdir -pm755 /etc/apt/keyrings
sudo wget -O /etc/apt/keyrings/winehq-archive.key https://dl.winehq.org/wine-builds/winehq.key
sudo apt update
sudo apt install winehq-stable
for Ubuntu 22.04(Or Linux mint 21):
sudo wget -NP /etc/apt/sources.list.d/ https://dl.winehq.org/wine-builds/ubuntu/dists/jammy/winehq-jammy.sources
sudo apt upgrade
sudo apt update
Rishon_JR
  • 1,028
