Possible Duplicate:
What is the difference between 32bit and 64 bit and which should I chose?
I read somewhere that Ubuntu 12.04 64-bit is recommended by Canonical.. but my machine is not AMD64.. So which one should I prefer? 64-bit or 32-bit?
If you are not using a 64-bit machine then the i386 (32-bit) image is the one for you...
Also going by your answer you say it's not AMD64 (an actual AMD processor) which is fine, AMD64 images will run on 64-bit Intel processors as well...
Your cpu is 32-bit. Use the 32-bit version.
gajdipajti
  • 3,501
If you're running a 64-bit Intel processor then I would highly suggest using the AMD64 images(these will still work), as some applications are only available to run on 64bit machines. Oracle 11g for example.
SQLSavant
  • 283
