I am required to run some video processing algorithms on IP camera stream. I don't have an IP Camera so my idea is to use a webcam as an IP cam for RTSP streaming, which the client machines can acquire and run the algorithms on. I learned that VLC can perform streaming from a webcam. I attached an old webcam to an Ubuntu machine. Here is the information.
$ v4l2-ctl --list-devices
SAMSUNG (SPC-A30M): SAMSUNG (SP (usb-0000:00:14.0-7):
/dev/video0
/dev/video1
$ v4l2-ctl --list-formats
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'YUYV'
Here is the driver info.
/dev/video0
Driver Info (not using libv4l2):
Driver name : uvcvideo
Card type : SAMSUNG (SPC-A30M): SAMSUNG (SP
Bus info : usb-0000:00:14.0-7
Driver version: 5.3.18
Capabilities : 0x84A00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Index : 0
/dev/video1
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04A00000
Metadata Capture
Streaming
Extended Pix Format
When i open MediaStream, do all the steps correctly, I get this error:
Your input can't be opened:
VLC is unable to open the MRL 'v4l2:///dev/video0'. Check the log for detail.
The log file contains:
-- logger module started --
main: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
main: playlist is empty
v4l2 error: cannot open device '/dev/video0': Operation not permitted
When i open Cheese, the camera is working fine and i can see the video.
For testing purpose, i set the /dev/video0 permissions to 777, still i get the same error.
This Post suggested to add the user to video group, i did that using sudo usermod -aG video ${USER} but no joy.
I also tried Motion in this post, but i couldn't get it working.
I also tried FFmpeg in this post, but i couldn't get that working as well.
I studied and tried this post, this post, this post, and many others, but nothing seems to help.
In the Driver Info section (above), i see not using libv4l2, could it be the cause of the problem? If so, how to solve this issue?
What am i doing wrong? My objective to to provide an RTSP stream form the USB Webcam attached to the Ubuntu Machine, to the client machines for processing in Java or Python. I am not bound to VLC, so i can use anything that gets the job done.
Can anyone suggest a working solution to the VLC problem or suggest any other tool that can do the job?
I tried many posts/solutions but none helped.
