I recently bought the cheapest infrared webcam I could find on the internet. It works fine on my Windows machine, however I can't get it to work on my Ubuntu 18.10. Can you please help?
What I've tried already:
  • opening Cheese says "No device found"
  • opening VLC, going to Media > Open Capture Device and trying to use /dev/video0 or /dev/video1 (I don't know why I get 2 of those when connecting the camera) says:
    Your input can't be opened: VLC is unable to open the MRL 'v4l2:///dev/video0'. Check the log for details."
    And here's the log:
    main debug: nothing to play
    main debug: processing request item: v4l2:///dev/video1, node: Playlist, skip: 0
    main debug: rebuilding array of current - root Playlist
    main debug: rebuild done - 1 items, index 0
    main debug: starting playback of new item
    main debug: resyncing on v4l2:///dev/video1
    main debug: v4l2:///dev/video1 is at 0
    main debug: creating new input thread
    main debug: Creating an input for 'v4l2:///dev/video1'
    main debug: requesting art for new input thread
    main debug: using timeshift granularity of 50 MiB
    main debug: using default timeshift path
    main debug: `v4l2:///dev/video1' gives access `v4l2' demux `any' path `/dev/video1'
    main debug: creating demux: access='v4l2' demux='any' location='/dev/video1' file='/dev/video1'
    main debug: looking for access_demux module matching "v4l2": 21 candidates
    v4l2 debug: opening device '/dev/video1'
    v4l2 error: cannot open device '/dev/video1': Operation not permitted
    main debug: looking for meta fetcher module matching "any": 1 candidates
    lua debug: Trying Lua scripts in /home/master/snap/vlc/770/.local/share/vlc/lua/meta/fetcher
    lua debug: Trying Lua scripts in /snap/vlc/770/usr/lib/vlc/lua/meta/fetcher
    lua debug: Trying Lua scripts in /snap/vlc/770/usr/share/vlc/lua/meta/fetcher
    main debug: no meta fetcher modules matched
    main debug: looking for art finder module matching "any": 2 candidates
    lua debug: Trying Lua scripts in /home/master/snap/vlc/770/.local/share/vlc/lua/meta/art
    lua debug: Trying Lua scripts in /snap/vlc/770/usr/lib/vlc/lua/meta/art
    main debug: no access_demux modules matched
    main debug: creating access: v4l2:///dev/video1
    main debug:  (path: /dev/video1)
    main debug: looking for access module matching "v4l2": 26 candidates
    main debug: no access modules matched
    lua debug: Trying Lua playlist script /snap/vlc/770/usr/lib/vlc/lua/meta/art/00_musicbrainz.luac
    main debug: dead input
    main debug: changing item without a request (current 0/1)
  • when running lsusb -t, I get:
    /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
    /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
         |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
             |__ Port 3: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
             |__ Port 3: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
         |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/8p, 480M
             |__ Port 1: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
             |__ Port 1: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
             |__ Port 3: Dev 4, If 0, Class=Hub, Driver=hub/4p, 480M
    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
         |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/6p, 480M
             |__ Port 1: Dev 7, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
             |__ Port 2: Dev 11, If 0, Class=Hub, Driver=hub/4p, 480M
                 |__ Port 4: Dev 12, If 0, Class=Hub, Driver=hub/4p, 480M
                     |__ Port 4: Dev 13, If 3, Class=Audio, Driver=snd-usb-audio, 12M
                     |__ Port 4: Dev 13, If 1, Class=Video, Driver=uvcvideo, 12M
                     |__ Port 4: Dev 13, If 4, Class=Mass Storage, Driver=usb-storage, 12M
                     |__ Port 4: Dev 13, If 2, Class=Audio, Driver=snd-usb-audio, 12M
                     |__ Port 4: Dev 13, If 0, Class=Video, Driver=uvcvideo, 12M
Zanna
  • 72,312
Vlad
I opened up synaptic (I recommend installing it) and looked up the VLC extensions. At first I thought I had to install vlc-plugin-zvbi but this is not available, at least no in 20.04.
I got it working with the following: sudo apt install vlc-plugin-access-extra vlc-plugin-base vlc-plugin-qt vlc-plugin-video-output vlc-plugin-video-splitter vlc-plugin-visualization
To be fair I didn't check to see if it worked with less packages. I just clicked all the multimedia options.
