I have a problem with Huawei E3372 modem.
Xubuntu 18.04.2 LTS did not detect it as a mobile broadband modem. E3372 is not detected.
I have checked lsusb, and here I can see the system detects it as 12d1:1506 Huawei Technologies Co., Ltd. but I cannot choose it in my Network Connections. It displays Mobile Broadband not enabled.
I have added
Huawei E3372
ATTR{idVendor}=="12d1", ATTR{idProduct}=="1506", RUN +="usb_modeswitch '%b/%k'"
in /lib/udev/rules.d/40-usb_modeswitch.rules.
I followed the steps in the posts
Huawei E3272 Ubuntu and Huawei usb 4G modem not detected
but in vain
configPack.tar.gz does not contain 12d1:1506. hence the following command
tar xf /usr/share/usb_modeswitch/configPack.tar.gz 12d1\:1506
didn't worked. Hence I followed the same code in the post
tar xf /usr/share/usb_modeswitch/configPack.tar.gz 12d1\:14fe
and went to the folder /usr/share/usb_modeswitch/
cp 12d1:14fe 12d1:1506
and added the line in the following file
add line to file /lib/udev/rules.d/40-usb_modeswitch.rules:
ATTR{idVendor}=="12d1", ATTR{idProduct}=="1506", RUN+="usb_modeswitch '/%k'"
Still it didn't work.
Again tried, added the following to the file /lib/udev/rules.d/77-mm-usb-device-blacklist.rules:
ATTRS{idVendor}=="12d1", ATTRS{idProduct}=="14fe", ENV{ID_MM_DEVICE_IGNORE}="1"
Nothing worked so far.
Your help is much appreciated. Thanks in advance.
nmcli d
DEVICE TYPE STATE CONNECTION
wlp2s0 wifi disconnected --
enp3s0 ethernet unmanaged --
ttyUSB0 gsm unmanaged --
lo loopback unmanaged --
lsmod | grep cdc
huawei_cdc_ncm 16384 0
cdc_wdm 20480 1 huawei_cdc_ncm
cdc_ncm 36864 1 huawei_cdc_ncm
usbnet 45056 2 cdc_ncm,huawei_cdc_ncm
