Using Ubuntu 18.04 up to date.
Have had LibreOffice intalled on this machine for a couple years using LibreOffice's ppa to have the latest version installed.
2-3 days ago the latest LibreOffice update showed up and proceeded to update as usual, only this one time... ended up broken.
While trying to update it always end up displaying this error message after aborting the operation:
trying to overwrite '/usr/lib/libreoffice/share/config/soffice.cfg/modules/smath/menubar/menubar.xml', which is also in package libreoffice-common 1:6.3.5~rc2-0ubuntu0.18.04.1~lo1
Tried with:
sudo apt-get remove --purge libreoffice*
and also:
sudo apt-get remove fonts-opensymbol libreoffice libreoffice-* openoffice.org-dtd-officedocument1.0 python*-uno uno-libs3-* ure ure-dbg
But didn't fix anything.
Tried with synaptic afterwards which identifies 21 broken packages, tried to fix 'em through synaptic but at some point aborts and displays the following error message:
E: /var/cache/apt/archives/libreoffice-math_1%3a6.4.2-0ubuntu0.18.04.2_amd64.deb: trying to overwrite '/usr/lib/libreoffice/share/config/soffice.cfg/modules/smath/menubar/menubar.xml', which is also in package libreoffice-common 1:6.3.5~rc2-0ubuntu0.18.04.1~lo1
W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:1 and /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:5
W: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:1 and /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:5
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:1 and /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:5
W: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:1 and /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:5
W: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:1 and /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:5
W: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:1 and /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:5
W: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:1 and /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:5
W: Target DEP-11-icons-hidpi (main/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:1 and /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:5
W: Target DEP-11-icons-large (main/dep11/icons-128x128.tar) is configured multiple times in /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:1 and /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:5
W: Target CNF (main/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:1 and /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:5
W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:1 and /etc/apt/sources.list.d/libreoffice-ubuntu-ppa-bionic.list:5
Right now i'd like to completely remove LibreOffice, remove LibreOffice's ppa and then install LibreOffice from "regular" Bionic repos.
Where should i start ?
Thank you very much in advance
