frederick@frederickpina:~$ sudo apt-get upgrade -y
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libreoffice-base : Depends: libreoffice-common (>= 1:6.4.0~beta1-2~) but 1:6.3.5-0ubuntu0.19.10.1 is installed
Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
Depends: libuno-cppuhelpergcc3-3 (>= 4.0.0~alpha) but it is not installed
Depends: libuno-sal3 (>= 5.1.0~alpha) but it is not installed
Depends: libuno-salhelpergcc3-3 (>= 1.4.0) but it is not installed
Depends: uno-libs-private but it is not installed
Breaks: libreoffice-common (< 1:6.4.2~rc1~) but 1:6.3.5-0ubuntu0.19.10.1 is installed
libreoffice-base-core : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
Depends: libuno-cppuhelpergcc3-3 (>= 5.3.0~alpha) but it is not installed
libreoffice-base-drivers : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
Depends: libuno-sal3 (>= 5.3.0~alpha) but it is not installed
libreoffice-calc : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
Depends: libuno-salhelpergcc3-3 (>= 3.6.0~beta) but it is not installed
libreoffice-common : Breaks: libreoffice-core (>= 1:6.4~) but 1:6.4.2-0ubuntu0.19.10.1 is installed
Breaks: libreoffice-style-tango (>= 1:6.4~) but 1:6.4.2-0ubuntu0.19.10.1 is installed
libreoffice-core : Depends: libreoffice-common (> 1:6.4.2) but 1:6.3.5-0ubuntu0.19.10.1 is installed
Depends: libuno-sal3 (>= 6.4.0~beta) but it is not installed
libreoffice-draw : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
libreoffice-gnome : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
libreoffice-gtk3 : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
libreoffice-impress : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
libreoffice-java-common : Depends: libjuh-java but it is not installed
Depends: libjurt-java but it is not installed
Depends: libridl-java but it is not installed
Depends: libunoil-java but it is not installed
Depends: libunoloader-java but it is not installed
libreoffice-math : Depends: libreoffice-core (= 1:6.3.5-0ubuntu0.19.10.1) but 1:6.4.2-0ubuntu0.19.10.1 is installed
libreoffice-report-builder : Breaks: libreoffice-common (< 1:6.4.2~rc1~) but 1:6.3.5-0ubuntu0.19.10.1 is installed
libreoffice-report-builder-bin : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
libreoffice-sdbc-firebird : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
libreoffice-sdbc-mysql : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
Depends: libuno-sal3 (>= 4.2.0~rc1) but it is not installed
libreoffice-sdbc-postgresql : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
Depends: libuno-sal3 (>= 4.1.0~alpha) but it is not installed
libreoffice-writer : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
python3-uno : Depends: libuno-cppu3 (>= 4.4.0~alpha) but it is not installed
Depends: libuno-sal3 (>= 5.4.0~alpha) but it is not installed
ure : Depends: uno-libs-private (= 1:6.4.2-0ubuntu0.19.10.1) but it is not installed
Depends: libuno-purpenvhelpergcc3-3 (>= 1.4.0) but it is not installed
Recommends: libjuh-java but it is not installed
Recommends: libjurt-java but it is not installed
Recommends: libridl-java but it is not installed
Recommends: libunoloader-java but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Asked
Active
Viewed 391 times
The problem is with libreoffice-math. If you remove that one, the rest will install perfectly okay. Try this:
sudo dpkg --purge libreoffice-math libreoffice
sudo apt-get -f install
sudo apt-get update
sudo apt-get dist-upgrade
That should fix it and the rest of all your LibreOffice apps should work just fine.
