Everything was working fine previous day when i turn on my laptop I'm stuck on restart loop unable to boot after GNU GRUB screen. My Ubuntu did updated previous day and i selected Restart later option
When i select Advance Option for Ubuntu i get 4 options as seen in image below
[Image][1]
Selecting both recover mode options i get
Loading Linux 5.3.0-42-generic ...
Loading initial ramdisk ...
then black screen then my system restart
and selecting other options i get black screen then my system restart
I have Tried this but don't work for me
Some posts suggested this solution On GRUB menu Press 'e' and changing quiet splash nomodeset Pressed Ctrl + X
still get black screen and computer restart
I have Ubuntu IOS on usb but the installing Ubuntu i don't get reinstalling Ubuntu while keeping my data
Recovered my data but fresh installation also have same problem after Update
My system: Dell inspiron i3 15 3567 Intel HD 520 integrated
Thanks in advance
Edit 1:
i tried to apply these solutions but none works for me Ubuntu 18.04.2 boot stuck on purple screen after updates
After trying to fix my problem i know my Ubuntu Break (hang to purple screen) after these updated is installed and computer is restarted as shown in image below
Ubuntu update list
I really cant do any more debugging because i need my laptop for work
System info :
     Intel(R) Core(TM) i3-6006U CPU @ 2.00GHz
     VGA compatible controller
     product: Skylake GT2 [HD Graphics 520]
     vendor: Intel Corporation
I have a Dell Inspiron 17 5767 which was exhibiting the same issue(s). A clean Ubuntu 18.04.4 install works fine. But as soon as I updated packages, when this jumped to kernel 5.3.0.28-generic, my laptop stopped booting, and froze at "loading initial ramdisk". Using dis_ucode_ldr did not help. Updating the Dell BIOS did not help. When adding debug options to the kernel command line, nothing was displayed.
This link solved the problem for me: Ubuntu 20.04 black screen after installing, no booting "The problem is with UEFI. To fix it you can turn off PPT in the UEFI/BIOS options and enable Legacy Boot."
When I disabled PPT and enabled Legacy Boot, my Dell laptop recovered and can now boot successfully. Hopefully this might help.
