I have recently bought a Thinkpad T490 with an Intel i7 CPU and an NVIDIA GeForce MX250 graphics card (and an integrated Intel HD-Graphics 620) and installed Ubuntu 18.04 LTS. After encountering some graphics bugs I wanted to check whether all drivers are up to date.
The first thing I noticed is that in the "Additional Drivers" tab of software-properties-gtk, Intel is listed as "Intel Corporation: Unknown - this device is not working" and my Nvidia graphics card is listed as "NVIDIA Corporation: Unknown" (see image).
Next I tried to open "NVIDIA X Server Settings", but the window is almost empty (image). When I open it from console via nvidia-settings, i get the following output:
# nvidia-settings
ERROR: Error querying enabled displays on GPU 0 (Missing Extension).
ERROR: Error querying connected displays on GPU 0 (Missing Extension).
** Message: 09:38:37.446: PRIME: Requires offloading
** Message: 09:38:37.446: PRIME: is it supported? yes
ERROR: nvidia-settings could not find the registry key file. This
       file should have been installed along with this driver at
       /usr/share/nvidia/nvidia-application-profiles-key-documentati
       on. The application profiles will continue to work, but
       values cannot be prepopulated or validated, and will not be
       listed in the help text. Please see the README for possible
       values and descriptions.
I have tried disabling secure boot, since that seems to have fixed similar problems for other people, but that didn't change anything. I also tried installing newest NVIDIA-drivers, as was indicated in many posts with similar problems, but nothing changed.
Update: I removed all drivers with sudo apt purge nvidia* and reinstalled the latest driver (440) as instructed in this thread. Nothing changed, except that in nvidia-settings there is now only the "prime-profiles" option, so even less then before (see image).
Some outputs that might be relevant:
# lshw -c display
  *-display
       description: VGA compatible controller
       product: UHD Graphics 620 (Whiskey Lake)
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 02
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:147 memory:dc000000-dcffffff memory:70000000-7fffffff ioport:3000(size=64) memory:c0000-dffff
  *-display
       description: 3D controller
       product: GP108M [GeForce MX250]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:3c:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: driver=nvidia latency=0
       resources: irq:156 memory:db000000-dbffffff memory:80000000-8fffffff memory:90000000-91ffffff ioport:2000(size=128)
# lspci -v
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (Whiskey Lake) (rev 02) (prog-if 00 [VGA controller])
    Subsystem: Lenovo Device 2278
    Flags: bus master, fast devsel, latency 0, IRQ 147
    Memory at dc000000 (64-bit, non-prefetchable) [size=16M]
    Memory at 70000000 (64-bit, prefetchable) [size=256M]
    I/O ports at 3000 [size=64]
    [virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
    Capabilities: [40] Vendor Specific Information: Len=0c <?>
    Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
    Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
    Capabilities: [d0] Power Management version 2
    Capabilities: [100] Process Address Space ID (PASID)
    Capabilities: [200] Address Translation Service (ATS)
    Capabilities: [300] Page Request Interface (PRI)
    Kernel driver in use: i915
    Kernel modules: i915
3c:00.0 3D controller: NVIDIA Corporation GP108M [GeForce MX250] (rev a1)
    Flags: bus master, fast devsel, latency 0, IRQ 156
    Memory at db000000 (32-bit, non-prefetchable) [size=16M]
    Memory at 80000000 (64-bit, prefetchable) [size=256M]
    Memory at 90000000 (64-bit, prefetchable) [size=32M]
    I/O ports at 2000 [size=128]
    Capabilities: [60] Power Management version 3
    Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
    Capabilities: [78] Express Endpoint, MSI 00
    Capabilities: [100] Virtual Channel
    Capabilities: [250] Latency Tolerance Reporting
    Capabilities: [258] L1 PM Substates
    Capabilities: [128] Power Budgeting <?>
    Capabilities: [420] Advanced Error Reporting
    Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
    Capabilities: [900] #19
    Kernel driver in use: nvidia
    Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
I always had issues when installing NVIDIA drivers from ppa:graphics-drivers, I would suggest downloading the drivers from NVIDIA's website.
Installation (some commands require "sudo")
Once you've downloaded the correct driver for your card:
  • Set the run file as runnable (either via the properties menu or via command line)
    • command: chmod u+x <file> to add the execute bit for the current user on the specified file
NOTE: you'll have to do this part in CLI only (no visuals, I suggest opening this on your phone to follow along, you can press ctrl+alt+F1 you may need to use F2, F3, F4, etc.)
  • Stop your display manager (gdm by default or whichever one you have)
    • command: service gdm stop
  • Change the run level (this doesn't seem to be required anymore, but just in case)
    • command: init 3
  • Change to the directory of the NVIDIA installation run file
    • command: cd ~/Downloads/
  • Run the run file
    • command: ./NVIDIA... (tab completion should be possible, otherwise use ls to check the name)
    • if it fails due to gcc version, you can attempt to ignore the gcc version using the following command: ./NVIDIA... --no-cc-version-check
    • if this doesn't work, either downgrade your gcc version to the requested version or upgrade your kernel version (rather try downgrading gcc or setting the default gcc to an older one temporarily)
    • e.g. if you need gcc 5.x (don't forget to undo it afterwards, first command is to check the current link for /usr/bin/gcc)
ls -l /usr/bin/gcc
unlink /usr/bin/gcc
sudo ln -s /usr/bin/gcc-5 /usr/bin/gcc
  • Follow the prompts (dkms doesn't work for me currently, 32-bit libraries is up to you, etc.) (default selection if it fails to install)
  • Reboot
    • command: reboot
Checking if it succeeded
I usually test by using any of the following or all of them:
  • glxinfo|egrep "OpenGL vendor|OpenGL renderer*"
  • nvidia-settings
  • nvidia-smi
Footer
I can see you are already familiar enough with Ubuntu that you don't need some of the commands stated for you, I'm doing that for anyone else who might stumble across this, hopefully it helps them too
Extras
Neat extra: the run file has many flags, to list them, you can use -A flag like so: ./NVIDIA... -A
Dan
  • 61
