I followed this answer two days ago to activate hibernation on my fresh install of ubuntu 18.04 and it worked.
I then managed to break the filesystem so completely that a clean reinstall seemed like the easiest way. So I reinstalled ubuntu (using the "other" option in the installer) with a /tmp, swap, /boot and / partition. Exactly as I did last time. I then followed that answer again to set up hibernate.
Hibernating works - but resuming does not:
When I perform a systemctl hibernate, my laptop screen instantly turns black and only the led on the power button indicates any difference to a complete shutdown - that's good. However, the laptop does not respond to any interaction like keyboard inputs or short presses on the power button. The only option is to press the power button for 15 seconds to cause a forced shutdown, followed by a normal press to start it again.
Here is some information about my system:
generic@motorbrot-linux:~$ cat /sys/power/state
freeze mem disk
generic@motorbrot-linux:~$ grep swap /etc/fstab
# swap was on /dev/nvme0n1p7 during installation
UUID=93232136-5a6d-4ffc-b40d-809ccead48df none swap sw 0 0
generic@motorbrot-linux:~$ cat /etc/default/grub
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
#GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# FOR HIBERNATION
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash resume=UUID=93232136-5a6d-4ffc-b40d-809ccead48df"
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
One thing I noticed is that update-initramfs and update-grub displayed its output twice. Following this answer got rid of that, but I'm puzzled why I have two linux image still:
generic@motorbrot-linux:~$ sudo update-grub
[sudo] password for generic:
Sourcing file `/etc/default/grub'
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.3.0-42-generic
Found initrd image: /boot/initrd.img-5.3.0-42-generic
Found linux image: /boot/vmlinuz-5.3.0-28-generic
Found Windows Boot Manager on /dev/nvme0n1p2@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for EFI firmware configuration
done
I'm looking for guidance on how to make my laptop resume after I sent it into hibernation. In case that is relevant, I have a dual boot system with ubuntu 18.04 and windows 10.
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 1085439 1083392 529M Windows recovery environme
/dev/nvme0n1p2 1085440 1288191 202752 99M EFI System
/dev/nvme0n1p3 1288192 1320959 32768 16M Microsoft reserved
/dev/nvme0n1p4 1320960 614399999 613079040 292.3G Microsoft basic data
/dev/nvme0n1p5 614400000 614985727 585728 286M Linux filesystem
/dev/nvme0n1p6 614985728 628658175 13672448 6.5G Linux filesystem
/dev/nvme0n1p7 628658176 667719679 39061504 18.6G Linux swap
/dev/nvme0n1p8 667719680 1953523711 1285804032 613.1G Linux filesystem
I just tried systemctl suspend and the same thing happens there: Screen instantly goes black, and the only way to get it back on is to force shutdown by pressing the power button for about 20 seconds. Sometimes instead of a black screen after suspending, I get a frozen black screen with a cursor on it that won't move. This Answer suggesting that the nouveau driver is at fault did not help.
Pinging the "hibernated" system gets no reaction whereas pinging the fully-booted system does get replies.
Presssing the brightness keys on the black screen causes no reaction.
Here is an excerpt from my /var/log/syslog starting from "sleep requested" and ending at a point where I am reasonably certain that it is part of the booting up that followed, not the "hibernating" itself.
I have tried all three options reboot, platform and shutdown and they all freeze my screen.
I'm currently no longer experiencing this exact problem. For anybody with a thinkpad, perhaps ThinkWiki is helpful
