I have Kubuntu installed on an HP Omen and everything was fine until 2 events happened that I attribute may be due to the sound being completely gone.
The first was that a new update of the Nvidia 440 driver arrived from repository ppa: graphics-drivers / ppa
And the other event was that I wanted to install GLava in Kubuntu from a PPA but it could not be installed due to the lack of a library.
After that, I left the computer on, and when I came back there was no sound at all. There is no sound from the speakers and also when connecting headphones
I Uninstalled and reinstalled pulseaudio and nothing
I think it is a problem with HDA Nvidia with PavuControl all the profiles appear unplugged. I don't know how to fix it
Later I changed the nvidia driver to nouveau and it was worse because now only a black screen appears to log in and when logging in I access a terminal, I don't know what commands to use in case there are any to solve these problems.
nano
  • 51
Had the same problem, found a solution here on askubuntu and it worked for me! Ubuntu 18.04 audio disappeared after update
tomas reported that after adding a boot parameter to grub, their audio was restored. https://askubuntu.com/a/1218063/718497
So to answer my own question. After a lot of digging I finally managed to get my audio working again. After finding this thread https://bugs.archlinux.org/task/64720 I tried temporarily adding the boot parameter snd_hda_intel.dmic_detect=0 by following this guide: How do I add a kernel boot parameter? to verify that it worked. It solved my problem, and I added the key permanently now, and the fix seems to persist after reboot.
Please upvote tomas if it helps. :-)
(I would've posted this as a comment, but my rep isn't 50 just yet)
Tristan
  • 61
If sudo alsa force-reload says no modules loaded, try this:
sudo apt-get install --install-recommends linux-generic-hwe-18.04
and then reboot. The kernel update script had a problem in some kernels around version 4.15.0-... Supposedly, it was fixed from kernel version 4.15.0-109 onward, but in my case 4.15.0-109 and 4.15.0-111 caused another problem, with expanding kernel and system logs till my disk was full. The above works best and gets you to the newest kernel supported for 18.04 LTS (there are similar packages for other LTS versions).
kavadias
  • 3,777
