I have installed Ubuntu 18.04 on my Acer aspire VN7.
Problem: As sound output I get only "Dummy output". For sound input I get nothing at all. If I plug in headphones nothing happens. If I connect a soundbar via bluetooth it is displayed as the only output (dummy output disappears) and I can play music.
$ lsmod | grep snd_hda_intel
snd_hda_intel          53248  0
snd_intel_nhlt         20480  1 snd_hda_intel
snd_hda_codec         131072  1 snd_hda_intel
snd_hda_core           90112  2 snd_hda_intel,snd_hda_codec
snd_pcm               102400  3 snd_hda_intel,snd_hda_codec,snd_hda_core
snd                    86016  8 snd_seq,snd_seq_device,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,snd_pcm,snd_rawmidi
$ lspci -nnk | grep -A2 Audio
00:1f.3 Multimedia audio controller [0401]: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller [8086:a170] (rev 31)
    Subsystem: Acer Incorporated [ALI] Sunrise Point-H HD Audio [1025:1039]
    Kernel modules: snd_hda_intel
00:1f.4 SMBus [0c05]: Intel Corporation 100 Series/C230 Series Chipset Family SMBus [8086:a123] (rev 31)
$ sudo dmesg | grep -i audio
[    0.179482] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
My attempts to solve the problem:
I'm going forward to hearing your suggestions ;)
Update:
Setting back all files in /etc/pulse/ as supposed by mchid does not work (https://askubuntu.com/a/800280/167115)
But I found out something interesting/strange. If I boot Ubuntu 18 live from USB, sound works perfectly (output and input). So I compared /etc/modprobe.d/alsa-base.conf, /etc/pulse/default.pa and /etc/default/speech-dispatcher. They are identical.
Next I compared the packages which are installed between these two systems (apt list --installed). I found pulseaudio-module-bluetooth and libcanberra-pulse which are installed in the live version but were not installed on my installed OS. This was not the problem, still dummy output.
B Andi
  • 41
There seems to be a problem with 5.3.0-42-generic uname -r. I set my kernel to 5.3.0-28-generic (Set "older" kernel as default grub entry) and now sound works just fine.
PS: Ok, I'm pretty sure that someone suggested to change the linux kernel here, but now this answer has disappeared and I have to answer it myself. Thank you mysterious stranger ;)
B Andi
  • 41
