I downloaded Ubuntu Desktop 19.10 full Image, I checked the image and it is correct, after that, I used the mintstick tool to copy the iso to the pendrive.
When I boot it from my new PC, I get a grub command line prompt¿
How can I do to boot in live CD Image?
Alejo Dev
  • 101
If you just want to create a bootable USB
You can create a bootable usb with the regular tools available from command line in any distributions, like dd (substitute the path to your iso file and the path to the usb stick device file /dev/sd...)
sudo dd bs=8192 if=<path to iso> of=<path to usb device> conv=fdatasync  status=progress
See the similar question here: How to create a bootable Ubuntu USB flash drive from terminal?
If you want to understand why it will not boot
The process is explained here: Why Doesn't a Bootable USB Boot
