Since I don't see it mentioned here yet, you can use repren. While it isn't installed by default, it does support regular expression-based file renaming. You can do just a single regular expression pattern like so:
repren --rename --from "^[0-9]{3}" --to "" --dry-run .
The above example deletes the first 3 digits in all filenames if they are at the beginning thereof for all files recursively in the current directory. It does a dry run though to show you what it will do without actually doing it - remove the --dry-run bit once you're sure that it will do what you intend.
repren also supports pattern files, allowing you to do multiple replacements in 1 go:
repren --rename --patterns=path/to/patternfile
A pattern file looks like this:
regex_1<tab_character>replacement_1
regex_2<tab_character>replacement_2
...and so on.
Finally, it supports regular expression groups. Consider this pattern file:
# This is a comment
figure ([0-9+])<tab>Figure \1
The \1 syntax inserts the contents of the first (bracketed) group. To do this on the command-line, you'd need to use single quotes I think (correct me if I'm wrong):
repren --rename --from 'figure ([0-9+])' --to 'Figure \1' --dry-run path/to/directory_or_files_here
This is just scratching the surface of what repren is capable of though. It can optionally alter the contents of files too (hence the need for --rename in all the above examples).
Disclaimer: I am not affiliated with repren or it's development in any way, I just find it an invaluable time-saving tool.
