Using the perl-based rename command, then given
$ ls vort*.txt
vort-0.001.txt vort-0.01.txt vort-0.1.txt vort-0.2.txt
then
rename -n 's/(\d+\.\d+)/sprintf "%.2f", $1/e' vort*.txt
will impose 2-digit precision everywhere, as
rename(vort-0.001.txt, vort-0.00.txt)
rename(vort-0.1.txt, vort-0.10.txt)
rename(vort-0.2.txt, vort-0.20.txt)
If you want to rename to a minimum precision i.e. only modify filenames that currently have single-digit precision, then
$ rename -n 's/(\d+\.\d)(?=\D)/sprintf "%.2f", $1/e' vort*.txt
Remove the -n once you are happy that it is doing the right thing.
To do the same thing using bash shell manipulations alone,
for f in vort-?.?.txt; do
base=${f%.txt}
printf -v newname 'vort-%.2f.txt' "${base#vort-}"
echo mv -- "$f" "$newname"
done
Here, remove the echo after testing.
