196
I followed all the instructions stated at this question, but am encountering some problems with the last part of it.
I actually have version 6.22 of java and would like to update to version 6.30.
So after moving the extracted directory java-6-oracle into /usr/lib/jvm I do not know what to do, since the script that is pointed out in the answer above updates from java 5 to java 6.
For sake of clearness here is output if I do an ls in dir /usr/lib/jvm:
$ ls -l /usr/lib/jvm
total 8
lrwxrwxrwx  1 root root   14 2011-07-12 15:18 default-java -> java-6-openjdk
lrwxrwxrwx  1 root root   14 2011-07-12 12:19 java-1.6.0-openjdk -> java-6-openjdk
drwxr-xr-x 10 root root 4096 2012-04-12 12:06 java-6.31-oracle
drwxr-xr-x  7 root root 4096 2012-02-24 14:43 java-6-openjdk
What should I do now?
ADDED PART
Under the suggestion of @fossfreedom I ran the script anyway and actually it updated the java version.
In fact if I run command java -version output will be the following:
$ java -version
java version "1.6.0_31"
Java(TM) SE Runtime Environment (build 1.6.0_31-b04)
Java HotSpot(TM) Server VM (build 20.6-b01, mixed mode)
There is still a problem, if Irun javac -version it gives me the old version installed:
$ javac -version
javac 1.6.0_22
And if I use the tester at this link it will tell me that version is
Java Version 1.6.0_22 from Sun Microsystems Inc.
What's going wrong?
It seems that Java Runtime Environment has updated, but Java Compiler and Java plugin for browser have not.
How can I update them?
OTHER ADDED PART
sudo update-alternatives --config java will return following output
$ sudo update-alternatives --config java
There are 2 choices for the alternative java (providing /usr/bin/java).
  Selection    Path                                      Priority   Status
* 0            /usr/lib/jvm/java-6.31-oracle/bin/java     1062      auto mode
  1            /usr/lib/jvm/java-6-openjdk/jre/bin/java   1061      manual mode
  2            /usr/lib/jvm/java-6.31-oracle/bin/java     1062      manual mode
Press enter to keep the current choice[*], or type selection number:
these makes sense with the fact that JRE is correctly updated to version 6.31, issues are on Java Compiler and Java browser plugin.
Any ideas?
Kulfy
  • 18,154
Matteo
  • 2,357
8 Answers8
150
Re your first question:
possibly you may be confusing that the webupd8 script is 0.5b. That is the version of the script - it doesnt refer to the java version.
Further to the setting of the javac version.
I suspect you need to explicitly give the path of the javac compiler
i.e.
sudo update-alternatives --install "/usr/bin/javac" "javac" "/usr/lib/jvm/java-6.31-oracle/bin/javac" 1
followed by:
sudo update-alternatives --config javac
With regards to setting up the java chrome plugin.
The master question:
How do I install Oracle JDK 6?
includes this information - since your folder structure is slightly different your link command should be:
ln -s /usr/lib/jvm/java-6.31-oracle/jre/lib/i386/libnpjp2.so ~/.mozilla/plugins/
fossfreedom
  • 174,526
104
See this; run
sudo  update-java-alternatives --list
to list off all the Java installations on a machine by name and directory, and then run
sudo  update-java-alternatives --set [JDK/JRE name e.g. java-8-oracle]
to choose which JRE/JDK to use.
If you want to use different JDKs/JREs for each Java task, you can run update-alternatives to configure one java executable at a time; you can run
sudo  update-alternatives --config java[Tab]
to see the Java commands that can be configured (java, javac, javah, javaws, etc). And then
sudo  update-alternatives --config [javac|java|javadoc|etc.]
will associate that Java task/command to a particular JDK/JRE.
You may also need to set JAVA_HOME for some applications: from this answer you can use
export JAVA_HOME=$(readlink -f /usr/bin/java | sed "s:bin/java::")
for JREs, or
export JAVA_HOME=$(readlink -f /usr/bin/java | sed "s:jre/bin/java::")
for JDKs.
WillC
  • 1,758
28
I think you should take a look at the update-java-alternatives command from the java-common package and the *.jinfo files used by it. With that you should be able to switch completely between java installations (regardless of JDK, JRE, ...).
23
On ubuntu/linux you can switch java version using
But before, you need install the version.
You can use this script (./install-java.sh) to install multiple JVMs
#!/bin/sh
lookforJdks=$PWD
echo "Directory: $lookforJdks"
jdks=`test -e ./javac || find $lookforJdks -type d -iname '*jdk1.*' 2> /dev/null`
#set -e
echo 'which jdk do you want to choose? looking for jdks. This might take a while'
echo "$jdks" | awk '{printf("%5d : %s\n", NR,$0)}'
read choose
test -e ./javac || cd `echo "$jdks" | tr '\n' ',' | cut -d',' -f $choose`/bin
for e in appletviewer extcheck idlj jar jarsigner java javac javadoc javah javap jconsole \
 jdb jhat jinfo jmap jps jrunscript jsadebugd jstack jstat jstatd native2ascii rmic \
 schemagen serialver wsgen wsimport xjc jvisualvm jmc; do sudo update-alternatives \
 --install /usr/bin/$e $e $(readlink -f ./$e) 100; done
echo "RUN update-alternatives --config java"
Put this script in folder where has unpacked the JVM(s), and run:
/opt/install-java.sh
Next use:
muru
  • 207,228
If you are going to manualy set alternatives for javac javaws javadoc or any other java related commands, you might want to make them slaves of the java altenative.
sudo update-alternatives --install "/usr/bin/java" "java" "/opt/jdk1.8.0_74/bin/java" 0 --slave "/usr/bin/javadoc" "javadoc" "/opt/jdk1.8.0_74/bin/javadoc"
update-alternatives: updating alternative /opt/jdk1.8.0_74/bin/java because link group java has changed slave links
:/opt/jdk1.8.0_74$ sudo update-alternatives --display java
java - auto mode link best version is /opt/jdk1.8.0_74/bin/java link currently points to /opt/jdk1.8.0_74/bin/java link java is /usr/bin/java slave javadoc is /usr/bin/javadoc /opt/jdk1.8.0_74/bin/java - priority 0 slave javadoc: /opt/jdk1.8.0_74/bin/javadoc
Change /opt/jdk1.8.0_74/ with the dir where your jdk is installed.
Thiago
Default java version used by Ubuntu system.
Default javac used by Ubuntu.
Applications that use the environment variable $JAVA_HOME to find the java (jre or jdk) path.
export JAVA_HOME=/usr/lib/jvm/java-20-openjdk-amd64
danilo
  • 1,865
If you need, for example, to automatically switch to Java 8 (compiler 1.8), in an one-liner, for example for a script or continuous integration test suite, you can run
sudo update-java-alternatives -s $(sudo update-java-alternatives -l | grep 8 | cut -d " " -f1) || echo '.'
It will automatically fetch any java 8 version available and set it using the command update-java-alternatives.
The || echo '.' at the end just ensures the command returns success, because strangely update-java-alternatives by default returns error (1). You may skip it if you don't need this for a test suite.
If you want to switch to any other version just replace the 8 by the version you want in the previous command.
-1
Open /etc/environment in any your text editor and add the following line:
JAVA_HOME="usr/lib/jvm/open-jdk
- Java path could be diffrent.
Use source to load the variables, by running this command:
source /etc/environment
Then check the variable, by running this command:
echo $JAVA_HOME
With this path set, run this command:
Choose your default Java Version.
