Im trying to upgrade to 19.10 from my 19.04 which is EOL.
# apt update
4 packages can be upgraded. Run 'apt list --upgradable' to see them.
libgl1-mesa-dri/bionic-security 19.2.8-0ubuntu0~18.04.2 amd64 [upgradable from: 19.0.8-0ubuntu0~19.04.1]
libgl1-mesa-dri/bionic-security 19.2.8-0ubuntu0~18.04.2 i386 [upgradable from: 19.0.8-0ubuntu0~19.04.1]
libjavascriptcoregtk-4.0-18/bionic-security 2.26.4-0ubuntu0.18.04.1 amd64 [upgradable from: 2.26.2-0ubuntu0.19.04.1]
libwebkit2gtk-4.0-37/bionic-security 2.26.4-0ubuntu0.18.04.1 amd64 [upgradable from: 2.26.2-0ubuntu0.19.04.1]
apt -f upgrade
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
apt dist-upgrade
apt install libgl1-mesa-dri
 libgl1-mesa-dri : Depends: libsensors4 (>= 1:3.0.0) but it is not installable
                   Breaks: libgl1-mesa-dri:i386 (!= 19.2.8-0ubuntu0~18.04.2) but 19.0.8-0ubuntu0~19.04.1 is to be installed
 libgl1-mesa-dri:i386 : Breaks: libgl1-mesa-dri (!= 19.0.8-0ubuntu0~19.04.1) but 19.2.8-0ubuntu0~18.04.2 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
So how do I then do the sudo do-release-upgrade as this is complaining about I need to install updates
Martin-
  • 113
Although you are trying to upgrade to 19.10 (eoan) from 19.04 (disco), your sources contain some 18.04 (bionic) entries. Use the following command to find them:
grep -r bionic /etc/apt/sources.list*
Then use your favorite text editor to edit the found files and remove or upgrade the bionic entries manually.
See also: How do I restore the default repositories?
Melebius
  • 11,750
