My laptop (Dell Inspiron 5590 with Ubuntu 19.10 and kernel 5.3.0-40) was working fine until yesterday. When I turned it on I could not connect to the internet. I noticed that "Aeroplane mode" was switched on, but when I switched it off it said "No Wi-Fi Adapter Found" in settings. I also noticed that if I left the computer inactive for a short time it would freeze.
This is similar to: 19.10: Thinkpad L13: Intel 9560: wifi interface suddenly disappeared and Intel Wifi Card Stopped Working After Software Update
A comment to the above post suggested booting with a previous kernel (5.3.0-29). When I do this I can detect the Wi-Fi adapter and connect to the internet with no problems. However the system still freezes after a short amount of inactivity. Please can anyone advise me on this problem. Thanks!
Note: I do not have a Wi-Fi switch button to toggle. And I checked that Wi-Fi is enabled on the BIOS.
Output about Wi-Fi adapter, firmware and kernel:
>>lspci -nn | grep -i network
00:14.3 Network controller [0280]: Intel Corporation Device [8086:02f0]
>>uname -r
5.3.0-40-generic
>>iwconfig
lo no wireless extensions.
>>sudo lshw -C network
*-network
description: Network controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: irq:16 memory:c2218000-c221bfff
>> sudo dpkg -s linux-firmware | grep Ver
Version: 1.183.4
>> modinfo iwlwifi | egrep 'filename|intree'
filename: /lib/modules/5.3.0-40-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
intree: Y
>> rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Here are two outputs from dmesg:
>> dmesg | grep -i firm
[ 0.152619] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 2.420343] iwlwifi 0000:00:14.3: loaded firmware version 48.4fa0041f.0 op_mode iwlmvm
[ 2.462387] Bluetooth: hci0: Firmware revision 0.0 build 62 week 31 2019
[ 2.686507] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 2.862605] [Firmware Bug]: ACPI(PXSX) defines _DOD but not _DOS
[ 3.497542] iwlwifi 0000:00:14.3: Loaded firmware version: 48.4fa0041f.0
[ 3.497731] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
>>dmesg | grep iwl
[ 2.366865] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 2.420150] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 43.2.23.17
[ 2.468834] iwlwifi 0000:00:14.3: Detected Intel(R) Wireless-AC 9462, REV=0x354
[ 3.497417] iwlwifi 0000:00:14.3: Collecting data: trigger 15 fired.
[ 3.497541] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 3.497541] iwlwifi 0000:00:14.3: Status: 0x00000000, count: -144310389
[ 3.497543] iwlwifi 0000:00:14.3: 0xEEB1EBD3 | ADVANCED_SYSASSERT
[ 3.497544] iwlwifi 0000:00:14.3: 0x58011C15 | trm_hw_status0
[ 3.497544] iwlwifi 0000:00:14.3: 0x60C5819E | trm_hw_status1
[ 3.497545] iwlwifi 0000:00:14.3: 0x7EBF2DF8 | branchlink2
[ 3.497545] iwlwifi 0000:00:14.3: 0xAE9FEC6A | interruptlink1
[ 3.497546] iwlwifi 0000:00:14.3: 0xD6C20A3C | interruptlink2
[ 3.497546] iwlwifi 0000:00:14.3: 0x81524AD0 | data1
[ 3.497547] iwlwifi 0000:00:14.3: 0xC7FD9BBF | data2
[ 3.497547] iwlwifi 0000:00:14.3: 0x6BFEF09C | data3
[ 3.497548] iwlwifi 0000:00:14.3: 0x81448886 | beacon time
[ 3.497548] iwlwifi 0000:00:14.3: 0x29C07820 | tsf low
[ 3.497549] iwlwifi 0000:00:14.3: 0xFEF57BD7 | tsf hi
[ 3.497549] iwlwifi 0000:00:14.3: 0x97EB7B0D | time gp1
[ 3.497550] iwlwifi 0000:00:14.3: 0x8887938B | time gp2
[ 3.497550] iwlwifi 0000:00:14.3: 0xC6A8C241 | uCode revision type
[ 3.497551] iwlwifi 0000:00:14.3: 0xD8EBBC3F | uCode version major
[ 3.497551] iwlwifi 0000:00:14.3: 0xBBA5EB7F | uCode version minor
[ 3.497552] iwlwifi 0000:00:14.3: 0x4A922D18 | hw version
[ 3.497552] iwlwifi 0000:00:14.3: 0x8416AC04 | board version
[ 3.497553] iwlwifi 0000:00:14.3: 0xD2084183 | hcmd
[ 3.497553] iwlwifi 0000:00:14.3: 0x5B77FBFF | isr0
[ 3.497553] iwlwifi 0000:00:14.3: 0xEBB7B4E3 | isr1
[ 3.497554] iwlwifi 0000:00:14.3: 0xB2478CDC | isr2
[ 3.497554] iwlwifi 0000:00:14.3: 0x2590D985 | isr3
[ 3.497555] iwlwifi 0000:00:14.3: 0xFDFB7EE5 | isr4
[ 3.497555] iwlwifi 0000:00:14.3: 0x755BCBC3 | last cmd Id
[ 3.497556] iwlwifi 0000:00:14.3: 0x55C00030 | wait_event
[ 3.497556] iwlwifi 0000:00:14.3: 0x72033383 | l2p_control
[ 3.497557] iwlwifi 0000:00:14.3: 0xF3D7D9CE | l2p_duration
[ 3.497557] iwlwifi 0000:00:14.3: 0xDA9CC4BE | l2p_mhvalid
[ 3.497558] iwlwifi 0000:00:14.3: 0x44418141 | l2p_addr_match
[ 3.497558] iwlwifi 0000:00:14.3: 0x75022011 | lmpm_pmg_sel
[ 3.497559] iwlwifi 0000:00:14.3: 0x7A776FEB | timestamp
[ 3.497559] iwlwifi 0000:00:14.3: 0xF6BEF69E | flow_handler
[ 3.497609] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 3.497609] iwlwifi 0000:00:14.3: Status: 0x00000000, count: 7
[ 3.497610] iwlwifi 0000:00:14.3: 0x201013F1 | ADVANCED_SYSASSERT
[ 3.497610] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 3.497611] iwlwifi 0000:00:14.3: 0xC008CF5C | umac branchlink2
[ 3.497611] iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink1
[ 3.497612] iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink2
[ 3.497612] iwlwifi 0000:00:14.3: 0x00000003 | umac data1
[ 3.497613] iwlwifi 0000:00:14.3: 0x20000302 | umac data2
[ 3.497613] iwlwifi 0000:00:14.3: 0x00000201 | umac data3
[ 3.497614] iwlwifi 0000:00:14.3: 0x00000030 | umac major
[ 3.497614] iwlwifi 0000:00:14.3: 0x4FA0041F | umac minor
[ 3.497615] iwlwifi 0000:00:14.3: 0x00005C89 | frame pointer
[ 3.497615] iwlwifi 0000:00:14.3: 0xC0887F58 | stack pointer
[ 3.497616] iwlwifi 0000:00:14.3: 0x00000000 | last host cmd
[ 3.497616] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 3.497632] iwlwifi 0000:00:14.3: Fseq Registers:
[ 3.497635] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_ERROR_CODE
[ 3.497637] iwlwifi 0000:00:14.3: 0x00260000 | FSEQ_TOP_INIT_VERSION
[ 3.497639] iwlwifi 0000:00:14.3: 0x80020006 | FSEQ_CNVIO_INIT_VERSION
[ 3.497641] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 3.497643] iwlwifi 0000:00:14.3: 0x42E1014D | FSEQ_TOP_CONTENT_VERSION
[ 3.497646] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 3.497648] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 3.497650] iwlwifi 0000:00:14.3: 0x00000201 | FSEQ_CNVR_ID
[ 3.497653] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 3.497657] iwlwifi 0000:00:14.3: 0x00000201 | CNVR_AUX_MISC_CHIP
[ 3.497662] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 3.497696] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 3.497729] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x5bfc, CPU2 Status: 0x3
[ 3.497729] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 3.509548] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
Just in case it is relevant here is a link to the log from my update manager /var/log/apt/history.log https://pastebin.com/B2LS6uB2
