Before the software update my wifi adapter was working. I suspected a hardware problem but when I inserted usb-startup disk wifi is working in "Try Ubuntu" session, so it is not a hardware problem.
My keyboard does not have wifi switch or toggle.
I tried everything in this post Intel Wifi Card not working on Ubuntu which seems the same problem as mine. However, suggestions in this post did not solve my issue.
I'm posting required informations about my wifi adapter, firmware and kernel
$ lspci -nn | grep -i network
00:14.3 Network controller [0280]: Intel Corporation Device [8086:02f0]
$ uname -r
5.3.0-40-generic
$ iwconfig
lo no wireless extensions.
enp0s20f0u4 no wireless extensions.
$ sudo lshw -C network
*-network
description: Network controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: irq:16 memory:64314000-64317fff
*-network
description: Ethernet interface
physical id: 2
bus info: usb@1:4
logical name: enp0s20f0u4
serial: ca:03:be:3f:c1:53
capabilities: ethernet physical
configuration: broadcast=yes driver=rndis_host driverversion=22-Aug-2005 firmware=RNDIS device ip=192.168.42.183 link=yes multicast=yes
$ dmesg | grep -i firm
[ 1.488471] psmouse serio1: elantech: assuming hardware version 4 (with firmware version 0x4d5f01)
[ 2.416593] iwlwifi 0000:00:14.3: loaded firmware version 48.4fa0041f.0 op_mode iwlmvm
[ 2.503685] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 2.548323] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 2.550570] Bluetooth: hci0: Found device firmware: intel/ibt-19-0-1.sfi
[ 3.516710] iwlwifi 0000:00:14.3: Loaded firmware version: 48.4fa0041f.0
[ 3.517013] iwlwifi 0000:00:14.3: Firmware not running - cannot dump error
[ 4.106725] Bluetooth: hci0: Waiting for firmware download to complete
[ 4.107273] Bluetooth: hci0: Firmware loaded in 1524482 usecs
Additionally, I also checked /var/log/apt/history.log file to see what is updated by the update-manager
Here's the result
Start-Date: 2020-02-18 19:30:46
Commandline: aptdaemon role='role-commit-packages' sender=':1.650'
Install:
linux-image-5.3.0-40-generic:amd64 (5.3.0-40.32, automatic), linux-modules-extra-5.3.0-40-generic:amd64 (5.3.0-40.32, automatic), linux-headers-5.3.0-40-generic:amd64 (5.3.0-40.32, automatic),
linux-headers-5.3.0-40:amd64 (5.3.0-40.32, automatic),
linux-modules-5.3.0-40-generic:amd64 (5.3.0-40.32, automatic)
Upgrade:
libpam0g:amd64 (1.3.1-5ubuntu1.19.10.0, 1.3.1-5ubuntu1.19.10.1),
bluez:amd64 (5.50-0ubuntu4, 5.50-0ubuntu5),
poppler-utils:amd64 (0.80.0-0ubuntu1, 0.80.0-0ubuntu1.1),
gir1.2-nm-1.0:amd64 (1.20.4-2ubuntu2, 1.20.4-2ubuntu2.2),
linux-headers-generic:amd64 (5.3.0.29.33, 5.3.0.40.34),
linux-libc-dev:amd64 (5.3.0-29.31, 5.3.0-40.32),
libpam-modules:amd64 (1.3.1-5ubuntu1.19.10.0, 1.3.1-5ubuntu1.19.10.1),
bluez-cups:amd64 (5.50-0ubuntu4, 5.50-0ubuntu5),
linux-image-generic:amd64 (5.3.0.29.33, 5.3.0.40.34),
libpoppler-qt5-1:amd64 (0.80.0-0ubuntu1, 0.80.0-0ubuntu1.1),
google-chrome-stable:amd64 (79.0.3945.130-1, 80.0.3987.106-1),
libnm0:amd64 (1.20.4-2ubuntu2, 1.20.4-2ubuntu2.2),
libpam-runtime:amd64 (1.3.1-5ubuntu1.19.10.0, 1.3.1-5ubuntu1.19.10.1), network-manager:amd64 (1.20.4-2ubuntu2, 1.20.4-2ubuntu2.2),
apport:amd64 (2.20.11-0ubuntu8.2, 2.20.11-0ubuntu8.4),
python3-apport:amd64 (2.20.11-0ubuntu8.2, 2.20.11-0ubuntu8.4),
dmidecode:amd64 (3.2-2, 3.2-2ubuntu0.1),
libwebkit2gtk-4.0-37:amd64 (2.26.3-0ubuntu0.19.10.1, 2.26.4-0ubuntu0.19.10.1), libpam-modules-bin:amd64 (1.3.1-5ubuntu1.19.10.0, 1.3.1-5ubuntu1.19.10.1),
libfwupd2:amd64 (1.2.10-1ubuntu3, 1.2.10-1ubuntu4),
fwupd-signed:amd64 (1.10.1+1.2.10-1ubuntu3, 1.10.2+1.2.10-1ubuntu4),
bsdutils:amd64 (1:2.34-0.1ubuntu2.1, 1:2.34-0.1ubuntu2.2), network-manager-config-connectivity-ubuntu:amd64 (1.20.4-2ubuntu2, 1.20.4-2ubuntu2.2), bluez-obexd:amd64 (5.50-0ubuntu4, 5.50-0ubuntu5),
apport-gtk:amd64 (2.20.11-0ubuntu8.2, 2.20.11-0ubuntu8.4),
fwupd:amd64 (1.2.10-1ubuntu3, 1.2.10-1ubuntu4),
gir1.2-webkit2-4.0:amd64 (2.26.3-0ubuntu0.19.10.1, 2.26.4-0ubuntu0.19.10.1), linux-firmware:amd64 (1.183.3, 1.183.4),
libpoppler-cpp0v5:amd64 (0.80.0-0ubuntu1, 0.80.0-0ubuntu1.1),
libbluetooth3:amd64 (5.50-0ubuntu4, 5.50-0ubuntu5),
libpoppler-glib8:amd64 (0.80.0-0ubuntu1, 0.80.0-0ubuntu1.1),
libpoppler90:amd64 (0.80.0-0ubuntu1, 0.80.0-0ubuntu1.1), libjavascriptcoregtk-4.0-18:amd64 (2.26.3-0ubuntu0.19.10.1, 2.26.4-0ubuntu0.19.10.1), linux-generic:amd64 (5.3.0.29.33, 5.3.0.40.34), python3-problem-report:amd64 (2.20.11-0ubuntu8.2, 2.20.11-0ubuntu8.4),
xdg-desktop-portal:amd64 (1.4.2-2, 1.4.2-2ubuntu1),
gir1.2-javascriptcoregtk-4.0:amd64 (2.26.3-0ubuntu0.19.10.1, 2.26.4-0ubuntu0.19.10.1)
End-Date: 2020-02-18 19:32:39
Edit:
$ modinfo iwlwifi | egrep 'filename|intree'
filename: /lib/modules/5.3.0-40-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
intree: Y
$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Output of dmesg | grep iwl https://paste.ubuntu.com/p/gp6wWYR7tj/
