I tried to upgrade my dist from Ubuntu 19.04 to 19.10. Turned out, I had some packages to upgrade:
libgl1-mesa-dri/bionic-security 19.2.8-0ubuntu0~18.04.2 amd64 [upgradable from: 19.0.8-0ubuntu0~19.04.1]
libgl1-mesa-dri/bionic-security 19.2.8-0ubuntu0~18.04.2 i386 [upgradable from: 19.0.8-0ubuntu0~19.04.1]
dist-upgrade didn't upgrade them, so I tried to do it manually and this happened:
libgl1-mesa-dri : Depends: libsensors4 (>= 1:3.0.0) but it is not installable
Tried to install it manually, but it threw this:
marek@marek-GA-990XA-UD3:~$ sudo apt install libsensors4
Reading package lists... Done
Building dependency tree
Package libsensors4 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
libsensors4:i386 libsensors-config
E: Package 'libsensors4' has no installation candidate
updated information:
grep "bionic" /etc/apt/sources.list /etc/apt/sources.list.d/*
/etc/apt/sources.list:# deb-src [arch=amd64] https://download.docker.com/linux/ubuntu bionic stable
/etc/apt/sources.list:deb http://security.ubuntu.com/ubuntu bionic-security main
/etc/apt/sources.list.d/elastic-6.x.list:# deb https://artifacts.elastic.co/packages/6.x/apt stable main # wyłączony podczas aktualizacji do bionic
/etc/apt/sources.list.d/elastic-6.x.list.distUpgrade:# deb https://artifacts.elastic.co/packages/6.x/apt stable main # wyłączony podczas aktualizacji do bionic
/etc/apt/sources.list.d/elastic-6.x.list.save:# deb https://artifacts.elastic.co/packages/6.x/apt stable main # wyłączony podczas aktualizacji do bionic
/etc/apt/sources.list.d/heroku.list:# deb https://cli-assets.heroku.com/apt ./ # wyłączony podczas aktualizacji do bionic
/etc/apt/sources.list.d/heroku.list.distUpgrade:# deb https://cli-assets.heroku.com/apt ./ # wyłączony podczas aktualizacji do bionic
/etc/apt/sources.list.d/heroku.list.save:# deb https://cli-assets.heroku.com/apt ./ # wyłączony podczas aktualizacji do bionic
/etc/apt/sources.list.d/pgdg.list:# deb http://apt.postgresql.org/pub/repos/apt/ bionic-pgdg main # wyłączony podczas aktualizacji do cosmic
/etc/apt/sources.list.d/pgdg.list.distUpgrade:# deb http://apt.postgresql.org/pub/repos/apt/ bionic-pgdg main # wyłączony podczas aktualizacji do cosmic
/etc/apt/sources.list.d/pgdg.list.save:# deb http://apt.postgresql.org/pub/repos/apt/ bionic-pgdg main # wyłączony podczas aktualizacji do cosmic
Also, I found this answer: Cannot upgrade 19.04 to 19.10 because of held back packages: libsnmp30 and added this ppa repository:
sudo add-apt-repository ppa:oibaf/graphics-drivers
and it sorta worked, i.e. I was able to upgrade all packages etc. So my question is now: Should I clean this mess before I try to actually upgrade my system?
