When running update-manager to upgrade 19.04 to 19.10 I get this in the console:
Checking for a new Ubuntu release
Please install all available updates for your release before upgrading.
Trying do-release-upgrade:
$ do-release-upgrade
So trying upgrade:
$ sudo apt-get upgrade
The following packages have been kept back:
libsnmp30
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
In fact, it seems I cannot install anything:
$ sudo apt-get install emacs
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libsnmp30 : Depends: libsensors5 (>= 1:3.5.0) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Trying with --fix-broken:
$ sudo apt --fix-broken install
Correcting dependencies... failed.
libsnmp30 : Depends: libsensors5 (>= 1:3.5.0) but it is not installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
Anyway, libsnmp30 seems to be the culprit. Trying to install libsnmp30, I get this:
$ sudo apt-get install libsnmp30
Then trying libsensors5:
$ sudo apt-get install libsensors5
libsensors5 : Depends: libsensors-config but it is not going to be installed
Then trying libsensors-config, this is the result which looks scary enough:
$ sudo apt-get install libsensors-config
The following additional packages will be installed:
policykit-1-gnome
Suggested packages:
lm-sensors
The following packages will be REMOVED:
apturl cheese chrome-gnome-shell colord default-jre deja-dup evolution-data-server gdm3 gir1.2-gst-plugins-base-1.0 gir1.2-mutter-2
gir1.2-mutter-4 gir1.2-rb-3.0 gir1.2-totem-1.0 gnome-initial-setup gnome-online-accounts gnome-session-bin gnome-shell gnome-shell-extension-appindicator
[ ... lots and lots of packages ... ]
The following NEW packages will be installed:
libsensors-config policykit-1-gnome
0 upgraded, 2 newly installed, 120 to remove and 0 not upgraded.
Jikes!
More info:
$ apt-cache policy libsnmp30
libsnmp30:
Installed: 5.7.3+dfsg-1.8ubuntu3.1
Candidate: 5.7.3+dfsg-5ubuntu1.2
Version table:
5.7.3+dfsg-5ubuntu1.2 500
500 http://se.archive.ubuntu.com/ubuntu disco-updates/main amd64 Packages
5.7.3+dfsg-5ubuntu1 500
500 http://se.archive.ubuntu.com/ubuntu disco/main amd64 Packages
*** 5.7.3+dfsg-1.8ubuntu3.1 100
100 /var/lib/dpkg/status
Libsensors info:
$ apt-cache policy libsensors5 libsensors-config
libsensors5:
Installed: (none)
Candidate: 1:3.5.0-3ubuntu1
Version table:
1:3.5.0-3ubuntu1 500
libsensors-config:
Installed: (none)
Version table:
500 http://se.archive.ubuntu.com/ubuntu disco/main i386 Packages
Removing libsensors4:
$ sudo apt remove libsensors4
libgl1-mesa-dri : Depends: libsensors4 (>= 1:3.0.0) but it is not going to be installed
libsensors-config : Conflicts: libsensors4:i386 but 1:3.4.0-4 is to be installed
Info about libgl1-mesa-dri:
$ apt-cache policy libgl1-mesa-dri
libgl1-mesa-dri:
Installed: 19.3~git1908270730.e6eb44~oibaf~b
Candidate: 19.3~git1908270730.e6eb44~oibaf~b
Version table:
*** 19.3~git1908270730.e6eb44~oibaf~b 100
19.0.8-0ubuntu0~19.04.1 500
19.0.2-1ubuntu1 500
