I created a Linux Live USB key with Ubuntu 18.04 and turned off Secure Boot on my Surface Laptop 3, but whatever I try it just fails to boot! :-(
Regular boot (has "quiet splash" option)
-> MODSIGN: Couldn't get UEFI db list
Boot in compatability mode (has "nosplash" option)
-> hdaudioC0D2: Unable to bind the codec
No success with other versions of Ubuntu and Linux Mint I tried either. I tried modifying the boot options manually but I'm not sure how to turn off or choose a different audio driver/codec.
Regular boot after removing "quiet splash" option
Laptop starts getting loud and overheating after the line
[ OK ] Started udev Kernel Device Manager.
Regular boot after replacing "quiet splash" option with "text"
Either the same as above happens or I get this output:
A start job is running for Set the console keyboard layout (13s / no limit)
Kernel panic - not syncing: Timeout: Not all CPUs entered broadcast exception handler
xjcl
  • 653
What ended up working for me was
  1. When booting, edit the command line (press e) to add noapic to boot options
  2. Use Ubuntu Mate instead of Linux Mint because Cinnamon kept crashing
  3. Install kernel debian-test-2 from here so keyboard touchpad etc. work
xjcl
  • 653
