I have Asus G46V laptop running Ubuntu 18.04.3 LTS and when I open WiFi settings, I get this message: No Wifi adapter found
I tried this solution and this one but with no luck.
Here is my network card: 03:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4352 802.11ac Wireless Network Adapter [14e4:43b1] (rev 03) Subsystem: AzureWave BCM4352 802.11ac Wireless Network Adapter [1a3b:2123]
Here is the output of iwconfig:
$ iwconfig
lo        no wireless extensions.
enp4s0    no wireless extensions.
and here is the output of lspci -nn -d 14e4::
$ lspci -nn -d 14e4:
I then tried:
sudo apt update
sudo update-pciids
sudo apt install bcmwl-kernel-source
then sudo reboot, but with no luck.
Then, following this question I removed the installed driver using sudo apt-get purge bcmwl-kernel-source. I then installed sudo apt install firmware-b43-installer then
 sudo modprobe -r b43
 sudo modprobe b43
 sudo rfkill unblock all
but stil having No Wifi adapter found
As a side note, a bought a TP-Link AC600 Archer T2U Nano wifi USB dongle but it is also not working. Here is the question where I try to look for a solution.
I very much appreciate your help.
Edit 1:
I reinstalled bcmwl-kernel-source and here is the output of $ lspci -knn | grep Net -A3; rfkill list
:~$ lspci -knn | grep Net -A3; rfkill list
    Kernel modules: bcma, wl
04:00.0 Ethernet controller [0200]: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet [1969:1083] (rev c0)
    Subsystem: ASUSTeK Computer Inc. AR8151 v2.0 Gigabit Ethernet [1043:200f]
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
This problem looks like some kernel bug. The wl kernel module is not loading for some reason.
Try out if it has been fixed by updating your system by running:
sudo apt update && sudo apt upgrade
Pilot6
  • 92,041
