When I tried to install Cisco packet tracer from deb file it gave the following error:
Unpacking packettracer (7.3.0) ...
dpkg: dependency problems prevent configuration of packettracer:
packettracer depends on libdouble-conversion1; however:
Package libdouble-conversion1 is not installed.
packettracer depends on qt-at-spi; however:
Package qt-at-spi is not installed.
dpkg: error processing package packettracer (--install):
dependency problems - leaving unconfigured
Processing triggers for gnome-menus (3.32.0-1ubuntu1) ...
Processing triggers for desktop-file-utils (0.24-1ubuntu1) ...
Processing triggers for mime-support (3.63ubuntu1) ...
Processing triggers for shared-mime-info (1.10-1) ...
packettracer
Then I tried installing libdouble-conversion1 using command sudo apt-get install libdouble-conversion1 . It gives the following error
Package libdouble-conversion1 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libdouble-conversion1' has no installation candidate
