I recently upgraded Ubuntu from kernel 5.0.0-37 to 5.3.0-26 (x86_64). It seems coincident with this upgrade, my wifi USB dongle stopped working (Archer T4U). It normally has some flashing lights on the side, but they are now all unlit. I did boot into Windows to verify it is still functional, which it is. Here's the steps I did to attempt to get it operational again (I still have wired connectivity):
$sudo apt remove rtl8812au-dkms
$sudo apt install rtl8812au-dkms
Next, I check that I can see the USB dongle, and get the following output:
$cat /var/lib/usbutils/usb.ids | grep  "Archer T4U"
0101  RTL8812AU Archer T4U 802.11ac
0103  Archer T4UH wireless Realtek 8812AU
Good so far. Next, I check that it's part of my network:
$sudo lshw -C network
  *-network
       description: Ethernet interface
       product: 82567LM-3 Gigabit Network Connection
       vendor: Intel Corporation
       physical id: 19
       bus info: pci@0000:00:19.0
       logical name: eth2
       version: 02
       serial: b8:ac:6f:1d:64:14
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.4-3 ip=192.168.0.40 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:32 memory:f7fe0000-f7ffffff memory:f7fd9000-f7fd9fff ioport:ece0(size=32)
This shows my wired connection, but not the wifi USB. All the help I research on this makes the assumption that the system can see the wifi when this command is issued.
I check to verify it's in the USB id list:
$cat /var/lib/usbutils/usb.ids | grep  'Archer T4U'
That's okay. Next I check that the wifi module is installed:
$sudo lsmod | grep 8812au
8812au               1290240  0
cfg80211              704512  1 8812au
Yes, it is. Okay, let me try to activate the module:
$sudo modprobe 8812au
$echo $?
It seems it activated okay. Now I run iwconfig:
$iwconfig
lo        no wireless extensions.
eth2      no wireless extensions.
As with the previous lshw command, it doesn't see the wifi dongle as part of the network. I've tried rerunning these steps multiple times, which have always worked before, and have rebooted several times, all to no avail. I'm at a loss for how to get this working.
For kernel 5.3 you may need the newer / modified driver.
You could install the latest driver from this GitHub repo: https://github.com/aircrack-ng/rtl8812au.git
As per the repo, this is how you can install the driver using DKMS method:
sudo apt update
sudo apt install dkms
git clone -b v5.6.4.2 https://github.com/aircrack-ng/rtl8812au.git
cd rtl8812au
sudo ./dkms-install.sh
Your USB WiFi adapter should be working now.
Jags
  • 2,235
  • 28
  • 44
Thanks @Jags. I downloaded the sourcefile
https://github.com/abperiasamy/rtl8812AU_8821AU_linux/archive/master.zip
After I unzipped it, I performed the following sequence of commands which I put in a script file:
cd rtl8812AU_8821AU_linux-master
make
sudo make install
sudo modprobe rtl8812au
sudo apt-get update
# already installed
#sudo apt-get install dkms
sudo cp -R . /usr/src/rtl8812AU_8821AU_linux-1.0
sudo dkms add -m rtl8812AU_8821AU_linux -v 1.0
sudo dkms build -m rtl8812AU_8821AU_linux -v 1.0
sudo dkms install -m rtl8812AU_8821AU_linux -v 1.0
The dongle started flashing before it had finished the make. I checked my wifi, and it was already operational, and the make hadn't even finished yet! Go figure.
I am on Ubuntu 20.04 (and also 18.04), with 5.4.0-66-Generic kernel (uname -r), with a RTL8811au dongle which I used a few years ago on Ubuntu 16.04. I was having problems of connecting Wifi with a new ubuntu installation. I was asked to provide password after each cold boot.
The solution involves 2 parts.
  1. Install the correct wifi driver. Follow the above answer by @Jags above (see exact Github source/instruction for RTL8812au driver, other github solution didn't work). After the installation, I was able to see Wifi routers and connect to it, except that the wifi won't be connected after each reboot. It would ask for wifi password again even though password was saved in a prior successful link.
  2. I traced it to the dynamic interface name. (Do 'iwconfg', you will see the wireless interface name in this format: wlsxxxxxxxxxxxx', and it is different each time after reboot). The following code is used to force a persistent name.
     sudo cp /lib/udev/rules.d/80-net-setup-link.rules /etc/udev/rules.d/
     sudo vi /etc/udev/rules.d/80-net-setup-link.rules
    change "$env{ID_NET_NAME}" to "wlan0" instead of "$env{ID_NET_SLOT}", save, and reboot. Note that "$env{ID_NET_SLOT}" per the link below worked for me only when I do a hot plug of the wifi dongle. If I leave it on the computer, and reboot, it could not find any hotspot nearby.
Refer to solutions to avoid dynamic usb wifi interface name
VictorL
  • 111
